Pulley stopper bolt....... - Suzuki Burgman Forum
Reply
post #1 of 16 (permalink) Old 10-16-2011, 10:48 AM Thread Starter
Insane Poster
FWIW, I replaced the stopper bolt in our K9 650 in May of 2010 when we had 2600 miles. While installing the new stopper bolt I smeared a little wheel bearing grease around the end of the bolt. Well.......I just checked the bolt yesterday after 6100 miles (8700 total) and there wasn't any dimpling what-so-ever. I'm thinking that the grease must be helping to prevent any friction that might take place that causes the dimpling. Btw, it doesn't take much grease........just a thin film around the end of the bolt.
Presently-White Lightning 2009 Burgman 650 (wife's) 13,600 miles
Formerly-Blue 2007 Burgman 400 (wife's) 9980 miles-----SOLD TO BUY FATBOY
Formerly-Blue 2007 Burgman 400 (mine) 4985 miles-------SOLD TO BUY K9 650
Scootermikie is offline
Sponsored Links
post #2 of 16 (permalink) Old 10-16-2011, 10:56 AM
Insane Poster
Buffalo's Avatar
Re: Pulley stopper bolt.......
To tell the truth, I don't see how grease on the end of the bolt could do any good other than maybe providing a little cushion. The bolt doesn't slide against anything. It's there to keep the adjuster from turning.
I would caution anyone that decides to try this to keep the grease to a minimum. If any of it were to migrate out and get on the belt or pulley faces it would not be a good thing.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,093 miles
"Little Blue" 2006 Blue 400S - 47,506 miles
Buffalo is offline
post #3 of 16 (permalink) Old 10-16-2011, 11:03 AM
Super Poster
EthanolBurgman's Avatar
Quote:
Did the same thing, just used Never-Seez and some lithium grease on mine.
Allows that collar to slip a bit when in contact with the bolt, rather than stick in place and begin to cut into it.
2005 AN650 Burgman ("chipped" ECM) running on E-85 ethanol.
Custom engine oil, transmission and final drive fluids.
BMC (FM388/19) Air Filter. Power Commander III.
Xenon Headlights
EBC HH Brake Pads and Rotors.
TCB on all Brakes.
Metzeler (Made in Germany) FeelFree Tires.
EthanolBurgman is offline
post #4 of 16 (permalink) Old 10-16-2011, 12:25 PM
Insane Poster
LeDude's Avatar
I would listen to Buffalo on this one... I wouldn't introduce / inject any type of oil / lube into the CVT housing...
they went through a lot of trouble to keep that space as air tight and clean as possible...
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #5 of 16 (permalink) Old 10-16-2011, 12:40 PM
Insane Poster
Chet_Benson's Avatar
I no longer own a 650 but I would not be inclined to checked it at only 2600 miles. If something is tinkered with enough soon it will be screwed up. Rather hard to fix something that is not broken. Maybe at 10,000 or 15,000 to prevent a problem I would check it. And grease on a surface that does not slide is a poor idea. Grease also has thickness which may hurt the length of the bolt.
From the hills of Tennessee
Welcome to another day the Lord has made
2009 White Burgman 400
Chet_Benson is offline
post #6 of 16 (permalink) Old 10-16-2011, 12:51 PM Thread Starter
Insane Poster
Quote:
I guess I'm not sure exactly what the function of the bolt really is, but it seems there is some contact made, otherwise what causes the dimpling at the end of the bolt? And, like I said.........I used a very small amount of grease........just a thin film. Btw Craig, just wanted to say you did a great job replacing the belt on your scoot. Thanks for sharing the experience.
post #7 of 16 (permalink) Old 10-16-2011, 12:58 PM Thread Starter
Insane Poster
Quote:
Actually Chet, at 2600 miles the original bolt had some dimpling.......not severe like some guys had, but enough that I changed it. However, I did keep the original as a spare. Regarding the use of grease.......I guess it's one of those "to each his own" things. I'll continue to use a thin film of grease around the end of the bolt.
post #8 of 16 (permalink) Old 10-16-2011, 03:09 PM
Turbo Poster
I posted a message regarding the stopper bolt on my K9 650 a while back regarding whether the bike had the new design or old designed bolt. You can check the bolt head without removing anything. My 650 was purchased new (in Clearwater FL. at the Suzuki dealer, Chet) in April. It had the b6 stamped on the head so I will not be concerned for the first 10,000 miles.
Givi V46 top case with Admore LED tail/stop/directional signals
Modulator headlights
Break-Away cruise control
Hyper stoplight to replace reflector under the license plate
Oznium LED's
Utopia backrest
Garmin Nuvi 1490 GPS with Ram mount
Cramp Buster
X-Large Clearview windscreen
Marv is offline
post #9 of 16 (permalink) Old 10-16-2011, 03:17 PM
Insane Poster
Bill-Bill's Avatar
When I traded my 2009 650 it had over 25k on it and the bolt still looked good.
Bill
Enjoy the ride...
Miles - 2581 Average MPG 61.4
on the 2013 650.
Now on a 2013 Spyder RT
First fill-up 111 miles 26 MPG
Bill-Bill is offline
post #10 of 16 (permalink) Old 10-16-2011, 03:30 PM
Insane Poster
Buffalo's Avatar
The function of the stopper bolt is to act something like a wrench would on a bolt head when you are trying to undo the nut on the other end. The electric motor on the CVT is like the wrench that is trying to turn the nut. If the stopper bolt was not there the whole adjuster assembly would just spin and the ratio would not change. The stopper bolt keeps it from turning so the adjuster inside can be screwed in and out to change the pulley width and thus the ratio of the CVT.
The dimpling is caused when the adjuster housing hits up against the bolt each time the direction of the adjustment changes. If anything it would seem that the grease would make the bolt slip easier in the slot and increase the likely hood of dimpling.
Buffalo is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Primary Pulley Stopper Bolt HarryS Burgman 400 (2007+ model) 3 07-28-2012 05:51 AM
Primary Pulley Stopper Bolt thoughts Tromper Burgman 650 2 06-07-2012 09:00 PM
Cactuspwr primary pulley stopper bolt cactuspwr Burgman 650 1 11-15-2011 09:09 AM
Primary Pulley Stopper Bolt CalvinFold Burgman 650 32 09-04-2011 04:45 PM
Primary pulley stopper bolt helo-guy Newbie Questions! 5 05-19-2011 08:00 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
