So I replaced MY Pulley Bolt..and the story behind that - Suzuki Burgman Forum
post #1 of 9 (permalink) Old 06-10-2011, 11:51 PM Thread Starter
Active Member
So I finally went and did it....replaced the bolt. Unfortunately, like all of my other work..it is never that simple.
So first, I had to get a torque wrench..so it is off to Harbor Freight. Got a 1/4 inch since I have sockets for that size up to 1/2 inch.
Then I realized that my 14mm is a 3/8 socket. So it is off to Napa to get the adaptor.
On my back again with all of my tools...took the old bolt out.... Want to upload a picture of it but the file is too big..does have a rounded groove in it. Mileage is 47000 plus.
So I put the socket on the adaptor and the torque wrench, which is set at 26 lb/ft. I seated the bolt and then turned it using the socket wrench until it started snugging up.
Then over to the torque wrench and I started applying pressure...and continued to push until the pressure released....because the torque wrench nipple (sic) snapped right off in the adaptor...so now it is back to Harbor freight for both a new torque wrench and to get them to replace the adaptor..wish me luck.
mrwizard is offline
Sponsored Links
post #2 of 9 (permalink) Old 06-11-2011, 08:08 AM
Active Member
Location: south of Shickshinny across Susquehanna River from Nescopeck, PA
Re: So I replaced MY Pulley Bolt..and the story behind that
Your using the wrong tool for the job. 1/4" inch torque wrench is only good for 200 inch pounds which I believe is 16.6 foot pounds and your trying to tighten to 26 foot pounds. No wonder it snapped off. You need a 3/8 torque wrench.
Cheers
garyk-52
garyk_52 is offline
post #3 of 9 (permalink) Old 06-11-2011, 09:55 AM
Super Poster
Renegade1978's Avatar
If it's any consolation, I changed mine last week and had absolutely NO problems. He He.
Only a biker understands why a dog sticks his head out the car window!
2003 650
Kuryakyn ISO Grips
Givi Windshield & Topcase
Yoshimura exhaust
Racetech Gold Cartridge Emulators
Throttle Boss
Custom Seat by Cary Vincent
Renegade1978 is offline
post #4 of 9 (permalink) Old 06-11-2011, 11:53 AM
Insane Poster
LeDude's Avatar
the 1/4 " torque wrench isn't the right tool for this job, you really need a 3/8 torque wrench at least...
I believe the 1/4" maxes out at 200 lb-inch which is about 16 lbft.
I own all three of HF's torque wrenches and like them a lot, they are very accurate and work well too.
I use the 1/4" mainly for settings requiring low torque values, 5-10 lbs ft
to convert lb-in to lb-ft, divide by 12 and to convert lb-ft to lb-in multiply by 12.
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #5 of 9 (permalink) Old 06-11-2011, 01:01 PM
NormanB's Avatar
How do you know a torque wrench is accurate?
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
post #6 of 9 (permalink) Old 06-11-2011, 01:07 PM
MJR
Insane Poster
MJR's Avatar
Quote:
Good question. They should be sent for calibratation from time to time if absolute accuracy is important but I suppose you could compare them to others for a rough idea. All my new torque wrenches (Gearwrench) came with a certificate showing the tested accuracy to indicated.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650, Yoshi Carbon/Stainless Exhaust, Bazzaz Z-Scoot Fuel Control
'06 Oort Gray Burgman 650 rebuilt/upgraded CVT
'06 Oort Gray Burgman 650 another parts bike or project, CVT int failure
'05 Sonic Silver Burgman 650 body damaged, stripped down/rebuilding back up on hold
'03 Space Blue Burgman 650, rebuilt/upgraded CVT with Polish adapter
'03 Space Blue Burgman 650 parts bike, failed CVT splines/brg
www.gotgroceries.net
MJR is offline
post #7 of 9 (permalink) Old 06-11-2011, 03:26 PM
Insane Poster
While using my torque wrench I always tighten the bolt just a little less than specs. If specs call 16 ft/lbs I tighten until 15. I've heard of too many guys stripping threads when tightening to specs. And, I've never had a bolt come loose
Presently-White Lightning 2009 Burgman 650 (wife's) 13,600 miles
Formerly-Blue 2007 Burgman 400 (wife's) 9980 miles-----SOLD TO BUY FATBOY
Formerly-Blue 2007 Burgman 400 (mine) 4985 miles-------SOLD TO BUY K9 650
Scootermikie is offline
post #8 of 9 (permalink) Old 06-11-2011, 04:15 PM
Insane Poster
LeDude's Avatar
there are places that can test it for you, and there are plenty of DIY test methods you can find online.
there are also a few gadgets you can use like this one:
LeDude is offline
post #9 of 9 (permalink) Old 06-12-2011, 04:56 PM
Super Poster
Well at least you guys have the time to do it, and patience. I don't so I have mine done at the shop, and I REALLY had to explain to them the location of the bolt, they looked it up on the parts the page on there PC, still no joy, I told them to look it up on you tube and look for
Le Dude,s DIY instructions he did that on his cel ph, they dont have access to the internet. Once he did that he found the part on the part, I was only charged $8.00 for labor. Bike has 24 400 miles the older bolt does have some small dents, 2 onb the edge around the top and 2 small dengs on the side.
Present:
AN650K7 "Lets Burgie"
Past
2006 400S AN400S "Coyote"
1984 Honda Sabre V65 "Speed Racer"
1981 Honda F750 "Tooslow"
1979 Kawasaki KZ650 "POS"
1968 Yamaha 175 Enduro "Hardly"
w-coyote is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Primary pulley bolt Marv Burgman 650 21 03-30-2013 02:42 PM
Primary Pulley Stopper Bolt HarryS Burgman 400 (2007+ model) 3 07-28-2012 05:51 AM
Should I be worried; replaced Pulley Sensor MaxG Burgman 650 9 05-29-2012 04:54 PM
Pulley stopper bolt....... Scootermikie Burgman 650 15 10-21-2011 12:32 AM
Primary Pulley Stopper Bolt CalvinFold Burgman 650 32 09-04-2011 04:45 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
