FI indicator light - Suzuki Burgman Forum
post #1 of 10 (permalink) Old 04-25-2011, 01:56 PM Thread Starter
Ino
Super Poster
Ino's Avatar
FI indicator light
I have searched for this subject and got one hit. My question is has anyone "recently" experienced the FI light coming on and the bike still runs? When you took it to the mechanic was the situation more or less a reset or ???
My burgie is an '05 with approx 6K miles and until now, has been running like a charm and can't believe all of a sudden there is something "seriously" wrong with the Fuel injection system? Any similiar situations? thanks.
Ino
2007 Suzuki Burgman 400 with Velorex 700 Sidecar--Silver
2005 Suzuki Burgman 650 with Velorex 565 Sidecar--Blue (SOLD)
1978 Suzuki Angel Mo-Ped (48cc)--Blue
"4 wheels move my body but 3 wheels move my soul"
Ino is offline
Sponsored Links
post #2 of 10 (permalink) Old 04-25-2011, 02:37 PM
Insane Poster
Colchicine's Avatar
Re: FI indicator light
You couldn't find anything on "FI" because the forum only indexes words 3 letters or more.
An FI code can not be made to go away simply be resetting it. So here's what you need to do to figure out what needs to be done:
Go here and look at the instructions for the homemade diagnostics tester. The next time you get the code and before you turn off the bike, use the tester to get the code:
http://burgmanusa.com/bkb/650+Stock+Electrical
Then you can go here to determine what the code means.
http://3482243909406299846-a-1802744773 ... edirects=0
or
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #3 of 10 (permalink) Old 04-25-2011, 02:59 PM Thread Starter
Ino
Super Poster
Ino's Avatar
Colchine,
Thanks for the quick reply, I asked my independent bike mechanic if he had this special tool "the diagnostic toggle tool" and he told me its more of a generic tool that he has that can do the same. I also pulled out and dusted off the service manual for the burgie that I inherited from previous owner and walah! the codes are in it so I can bring that manual to mechanic as well.
But now the question is can I ride this bike approx. 15 miles to his shop without serious damage to it? It turns over and runs but seems like its restricted on the speed? I guess I should just call the tow truck to be safe?
Ino
Ino is offline
post #4 of 10 (permalink) Old 04-25-2011, 03:05 PM
Insane Poster
Colchicine's Avatar
These codes relate to some pretty serious components. If the code were for a Pulley Position Sensor (for example), and you rode on it, you could do thousands of dollars of damage to the CVT. Some components / sensors certainly won't have that affect, but the PPS is the more common FI code and is responsible for keeping a lot of the CVT parts together.
You can get the code yourself, then decide how you want to proceed. But if you're not going to do that, get it towed.
Kory's
post #5 of 10 (permalink) Old 04-25-2011, 03:10 PM Thread Starter
Ino
Super Poster
Ino's Avatar
Thanks, I will have it towed.
Ino
Ino is offline
post #6 of 10 (permalink) Old 04-25-2011, 03:16 PM
Active Member
Location: south of Shickshinny across Susquehanna River from Nescopeck, PA
Could the center stand switch be stuck and only allowing first gear?
Don't know if that throws the light thou.
garyk_52 is offline
post #7 of 10 (permalink) Old 04-25-2011, 03:19 PM
Insane Poster
Buffalo's Avatar
The center stand switch being stuck would not cause an FI code.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 135,222 miles
"Little Blue" 2006 Blue 400S - 47,656 miles
Buffalo is offline
post #8 of 10 (permalink) Old 04-25-2011, 03:24 PM Thread Starter
Ino
Super Poster
Ino's Avatar
This happened approx one ago, where the light came on and I felt restrictive power from the throttle and I quickly turned off the igntion and several minutes later after I cranked it back it up, the light went out. So it couldn't be the side stand switch (but just in case, where is it located at for future reference).
Now the light is on along with the restricted power.
Ino
Ino is offline
post #9 of 10 (permalink) Old 04-25-2011, 04:14 PM
Insane Poster
Buffalo's Avatar
The side stand switch is located at the top of the side stand. It is a punger type switch that is puched in when the side stand is retracted. It functions like the kill switch and keeps the bike from starting. It won't cause degraded power.
The center stand switch is also a plunger style switch. It is located on the right side bottom of the bike where the center stand pivots. It's purpose is to signal the computer that the bike bike is on the center stand. The computer will then lock the CVT in it's lowest ratio to limit wheel speed when the engine is running with the bike on the center stand. If it sticks in the closed position when you take the bike off the center stand then the bike will not upshift out of low gear when you take off.
Buffalo is offline
post #10 of 10 (permalink) Old 04-25-2011, 04:17 PM Thread Starter
Ino
Super Poster
Ino's Avatar
Thanks Buffalo,
But as you described and what you said earlier, I'm in agreement, either of those would not set off the FI light, but at least I know for future reference if one of them is either tripped or does not engage, I'll have one more place to check why the bike won't start up.
Ino
Ino is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
ABS indicator light shows Burgman 650 7 09-04-2010 06:07 PM
Oil change indicator light Tra Newbie Questions! 2 08-10-2010 05:53 PM
Voltage indicator and tail/brake light zeco Aftermarket and Accessories 3 06-09-2010 11:43 PM
Oil Pressure light / indicator on burger 650 K4 04 Wolvesboy21 Burgman 650 23 01-31-2009 07:05 PM
Oil Change Indicator Light Problem suziblu Burgman 400 (pre-2007) 10 12-10-2008 02:00 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
