Won't start. Solenoid? - Suzuki Burgman Forum
post #1 of 7 (permalink) Old 06-01-2010, 08:21 AM Thread Starter
Super Poster
hosejockey982's Avatar
Send a message via MSN to hosejockey982
Hey everyone, here's the situation. My bike has started pretty much fine over the past 93000 km's with just replacing the battery about half way thru. I installed a MC stereo yesterday, (intended for a MC), tried to start it and nothing.
Hooked up the battery, the relay, turned the key, got power to the bike (head lamps, gauges, accessories) turn the key and it made a "click" sound, then no power. A friend said it sounded like it had the ear markings of a solenoid. What do you guys think?
There's tons more knowledge here than I have and I was hoping someone could tell me if this sounds right? Also, where is the solenoid, an how do you replace it?
Thanks again everyone .
Brux
IBA #42574
SCRC #261072
2006 Suzuki Burgman 650 Executive
hosejockey982 is offline
Sponsored Links
post #2 of 7 (permalink) Old 06-01-2010, 10:00 AM
Insane Poster
Bill-Bill's Avatar
Re: Won't start. Solenoid?
If the scooter would start before you installed the radio and not after, I would retrace everything you did because it sounds more like you disconnected something rather then a solenoid being bad.
Bill
Enjoy the ride...
Enjoy the ride...
Miles - 2581 Average MPG 61.4
on the 2013 650.
Now on a 2013 Spyder RT
First fill-up 111 miles 26 MPG
Bill-Bill is offline
post #3 of 7 (permalink) Old 06-01-2010, 10:43 AM
Insane Poster
Buffalo's Avatar
A quick test to see if you possibly have a bad solenoid is to short across the two post on it with a screwdriver. A solenoid is just a switch. One of the heavy wires on it goes to the battery and the other goes to the starter. The solenoid connects the circuit to allow current to flow from the battery to the starter. If you short between the two post you will bypass the solenoid and let current flow directly to the starter. Even if the starter turns when you do this, it doesn't mean the solenoid is bad. You will also have to test the circuit from the starter switch to the solenoid to determine that current is flowing to energize the solenoid.
Warning before doing this put the bike on the centerstand, apply the parking brake and be sure nothing is contacting the rear wheel. When you short between the two post you will also be bypassing all the safety switches that keep the starter from turning when you don't want it to. The starter can turn even with the key in the off position. Also remember that the battery is right under the solenoid and if any hydrogen is outgassing from the battery an explosion can occur. Move the cover as far away from the battery as you can and use a fan or other air source to blow away any hydrogen that might have collected in the area before you short across the post.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,093 miles
"Little Blue" 2006 Blue 400S - 47,506 miles
Buffalo is offline
post #4 of 7 (permalink) Old 06-01-2010, 02:14 PM
NormanB's Avatar
I would first of all eliminate battery/charging problems.
It may be too weak - charge or get a jump from another vehicle before diving into deeper diagnosis.
Your recent work may have introduced an 'unauthorised' drain with the key in the off position - you can check by measuring in-line current.
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
post #5 of 7 (permalink) Old 06-01-2010, 03:16 PM
Insane Poster
Dave_J's Avatar
Hosejocky, I too think that your Starter relay is NOT the issue. Do you have access to a Volt-Ohm Meter (VOM) ? Using a VOM, measure the Voltage at the battery, should be at 12.5 volts. If below 11 volts the lights and stuff will still glow but the starter will only "CLICK".
I think, like said above, your wiring job for this "NEW" stereo is at fault. About 95% of the time if it worked before the Mod, but does not after the Mod, it must be the Mod.
Just about any Stereo has three power leads some have more. The Red for positive power, a Black for negitive and an Yellow for memory. If you put the red and yellow stright to battery and forget to power down the stereo, DEAD BATTERY and a "CLICK" noise. The Red wire (Acc) needs to go to a key switched power source so when the key is off, so is the stereo. The Yellow wire goes to the batterys positive and will keep all your stations in memory.
Please check your wiring and charge the battery.
Dave_J is offline
post #6 of 7 (permalink) Old 06-01-2010, 09:14 PM Thread Starter
Super Poster
Thanks guys I truly appreciate all your help. I was the new stereo, but for some reason connecting directly to the battery caused this problem. I disconnected everything, charged the battery, and then hooked the battery back up by itself and the bike fired right up first try.
So I got a 12v cigarette adaptor, and tried to power up the stereo that way, and it works fine. wonder why??
Anyway...thanks again!
Brux
IBA #42574
SCRC #261072
post #7 of 7 (permalink) Old 06-02-2010, 12:13 PM
Insane Poster
LeDude's Avatar
depending on the make and model of your radio/stereo equipment, just like a lot of household appliances, it could be drawing / consuming power even when it is turned off and the bike isn't running which could lead to draining your battery ...
just set up a Switched Power Supply Mgt. System and you be certain that the stereo/aux device isn't drawing anything once you turn off the bike.
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Possible Solenoid Problem ? jmccoymunster General Discussion 1 06-03-2011 11:07 PM
PAIR Control Solenoid Valve? notdeadman Burgman 400 (pre-2007) 5 10-27-2009 09:05 PM
Solenoid? qwertykev007 Burgman 400 (pre-2007) 6 11-29-2008 10:40 PM
Electric Solenoid Sound?? What is it?? donscip Burgman 650 8 08-07-2008 11:31 PM
Solenoid click RATMAN Newbie Questions! 6 06-17-2004 09:05 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
