Rear Tire Change - Suzuki Burgman Forum
post #1 of 9 (permalink) Old 09-02-2009, 10:55 AM Thread Starter
Super Poster
CaptJohn's Avatar
Rear Tire Change
Well, I have all the equipment, including the HF portable tire changer w/motorcycle attachment and MojoBlocks, a MojoLever and a Parnes balancer. I've changed tires from the ones on my old Harley Ultra w/cast wheels to Piaggio MP3's to Triumph spokes, etc; but the rear Bridgestone was, BY FAR, the most difficult tire to install on a rim!
The sidewalls are so rigid that I couldn't force the lip into the center channel of the rim and even though it was snugged down tight in the tire changer, the rim kept turning against the strain of the MojoLever. Finally, I used my hot air gun to warm the tire, used a ton of tire lubricant and the tire went on. HURRAY!!! And there isn't as much as a scratch on the wheel
I noticed that the factory didn't bother balancing the rear wheel; but I took the time to do it, and the results were a much smoother ride at freeway speeds. I think that balancing the wheel and running 41 psi in the rear will probably result in improved tire wear. By the way, I got 11,200 miles out of the original rear tire, and I always kept it at 41 psi.
Capt John
If you'd like to support my favorite Charity,
go to:
'08 Suzuki Burgman Exec Blk (His)
'07 Piaggio MP3 Blk (Sold)
'03 Aprilia Atlantic 500 Red (Sold)
'07 Piaggio MP3 Red (Sold)
CaptJohn is offline
Sponsored Links
post #2 of 9 (permalink) Old 09-02-2009, 12:20 PM
Insane Poster
LeDude's Avatar
Re: Rear Tire Change
I did mine about a month ago by hand and it was by far the most challenging tire I have ever mounted.
The difficulty arises from the very stiff bead and the rather small circumference. I lack the raw hand power to hold the bead down by hand so I had to resort to two 6 inch c-clamps to keep the bead from seating while trying to get it onto the rim... lubrication, lots of it, is definitely a primary element in getting this job done successfully.
It took me 4 tries before I could declare victory over the tire... The heat gun trick is a good one ....
I will be putting out a DIY video soon for those that may be interested in doing this themselves.
I always balance the wheel by iteself and then again with the tire on. My front tire required no weights but the rear needed about 14 grams to balance out...
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #3 of 9 (permalink) Old 09-02-2009, 01:34 PM Thread Starter
Super Poster
CaptJohn's Avatar
I was surprised that the factory didn't deem it necessary to balance the rear wheel, but I noticed a much smoother ride after doing so. Like you, I balance the rim before mounting the tire to find the exact heavy point to put the reference dot on the new tire. With the "pressure minder" valve cap, the valve stem was definitely the heavy point.
Warming the tire definitely made the job easier, along with tons of NoMar lube. I'm also going to get the "Yellow Thing":
http://www.nomartirechanger.com/products/10 and or the "XtraHand":
http://www.nomartirechanger.com/products/8
I think those devices could make the job one heck of a lot easier...
Capt John
go to:
CaptJohn is offline
post #4 of 9 (permalink) Old 09-02-2009, 02:08 PM
Insane Poster
paulcbrowne's Avatar
I have similar device and it did not help. I gave up and went to the dealer. That tire is THE WORST!!
Shepherdstown, WV USA
paulcbrowne is offline
post #5 of 9 (permalink) Old 09-02-2009, 03:22 PM
Ken
Insane Poster
I had similar problems installing my Michelin on the rear. This job is not an easy one and probably the most difficult cycle tire I have ever changed. I am not looking forward to the next change.
Ken
Blue 2003 Burgman 650
Ken is offline
post #6 of 9 (permalink) Old 09-02-2009, 04:09 PM
Insane Poster
LeDude's Avatar
the Nomar products are nice, but way over priced for what they do... c-clamps work just as well and do the same exact thing at a fraction of the price, I have 3 big 6" ones and a dozen or so smaller one in all sizes, 1,2,3,4 inches... I use clamp pads to keep the rim from being scratched or just use some left over pieces of leather or thick plastic.
HF c-clamp products
I usually leave my tire out in the sun for a few hours prior to mounting it but that didn't help too much with the rear tire for the 650, the bead is just too stiff, clamping it down with lots and lots of lube finally did the trick for me...
I mounted the tire the old fashion way with 3 tire irons. I may make a jig for the next tire change to keep the wheel in place and the tire pushed forward into the wheel cavity.
Just don't use too much force as you could end up damaging / bending the rim or removing chunks of rubber from the bead...
Of course it took half a dozen tries to just break the bead on the old tire, again, lots of repeaed lubrication did the trick.
LeDude is offline
post #7 of 9 (permalink) Old 09-02-2009, 04:29 PM
Insane Poster
malahy1501's Avatar
Location: Illinois, Morton ***TRAVEL STOP - Trailer Available***
I just returned from the Dealer, not Stealer this time with a new Michelin Pilot Sport SC on the rear of the Burger King...Bought the tire at Motorcycle Superstore ($111 delivered)...lashed it onto the back seat...and the Dealer only charged 1/2 hour labor to Remove, Balance and Replace on the bike...$32.50 labor As long as the dealer keeps this pricing, I'm not interested in learning how to change a tire I should be good for another year now
Had a similar pricing experience on my Goldwing a few weeks back...Times are slow I guess
Have a few more miles left to scrub it in, but it sure was nice to have a "round" rear again instead of the square slick
BTW the front Stone has 11,500 on it and has tons of tread left...I guess paying attention to tire pressure does make a difference
Bill
2003 Burgman 650
***TRAVEL STOP - Trailer***
Motorcycle riding is a dangerous hobby for many. It becomes a sport when one learns to master their ride.
Some days, it's not even worth chewing through the restraints
malahy1501 is offline
post #8 of 9 (permalink) Old 09-02-2009, 07:01 PM
Ken
Insane Poster
With that kind of pricing, I could easily forget how to change the rear tire. The local dealer (stealer) here wanted $100 labor to do what you had done.
Ken
Ken is offline
post #9 of 9 (permalink) Old 09-02-2009, 10:26 PM
Super Poster
I agree the rear tire is more difficult than some but not all that bad. I did mine in very warm weather using glass cleaner for lubricant (best thing I had). Using my knees to keep the one side pushed in I needed a 2 foot bar to get the final pop onto the rim. I used a crow bar wrapped with duct tape along with homemade rim protectors (old milk container) but now own several HF long tire irons for the next time.
kwalters is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Rear Tire change Colossal Burgman 400 (2007+ model) 10 06-06-2011 07:17 PM
Chronicles of a rear tire change Colchicine How To 16 10-04-2008 10:27 AM
Pics to change rear tire EdCG Burgman 400 (2007+ model) 7 05-22-2008 09:59 PM
Rear tire change on a 400 garyw0cki Burgman 400 (pre-2007) 22 09-12-2004 06:16 AM
Chronicles of a rear tire change Colchicine Burgman 650 15 12-31-1969 07:00 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
