Another oil question :( - Suzuki Burgman Forum
Reply
post #1 of 45 (permalink) Old 05-07-2009, 03:31 PM Thread Starter
Super Poster
TheBlackMoon's Avatar
Send a message via Yahoo to TheBlackMoon
Hey guys,
Okay, so I'm at my 4K and want to go full synthetic. I went down to the local Advance Auto Parts Store, picked up a few bottles to find which were NOT "Energy Conserving" and had the proper SF/SG API rating and ...
So, huh, HELP! I don't see ANY synth oils, not even the Mobil 1, that are rated SF/SG. They are mostly rated SM/SL.SJ/ and CF. Tried to make sense of the rating via the internet and found that the SF/SG rating is an obsolete rating and has been superceded, but by what is not clear! SM? Tried calling API and just kept getting answering machines. I think everyone took off for a new holiday or something.
So the question is, is it safe to use the NON-"Energy Conserving" Synth oils like Castrol Syntec and Mobil One that are rated SM/SL/SJ or do I swallow the duck and either go back to dino oil this trip around or wait and order some Amsoil (which would mean the dino oil, as I can't ride until I get the oil... I've already drained the old stuff! ).
Need some serious advice quick.
TheBlackMoon is offline
Sponsored Links
post #2 of 45 (permalink) Old 05-07-2009, 03:34 PM
Jim
Jim's Avatar
Re: Another oil question :(
Quote:
Non- Energy conserving IS what you want.
Pictures of Modifications and Accessories
Jim is offline
post #3 of 45 (permalink) Old 05-07-2009, 03:36 PM Thread Starter
Super Poster
So, are you saying that it is okay to use the SM/SL/SJ rated oil?
post #4 of 45 (permalink) Old 05-07-2009, 03:40 PM
Insane Poster
Colchicine's Avatar
Si Senior
I have a used oil analysis of Mobil 1 to prove it an acceptable oil.
Used Oil Analysis
* viewtopic.php?p=328465#p328465
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #5 of 45 (permalink) Old 05-07-2009, 03:48 PM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
You want an oil that DOES NOT HAVE any additional 'friction-reducing' additives (ie, "energy conserving", etc).
If you use any oil that is accepted by Suzuki, you will BE FINE. The owner's manual lays it out clearly.
You can use just about any brand of oil, dino or synthetic, in your scoot that meet's Suzuki's requirements. A synthetic oil is made by breaking down crude oil and then reassembling the molecular chains in a controlled environment and in a controlled way the precludes impurities and other 'bad' things that can cause a motor oil to break down during use. Combined with a great filter, you can extend your oil change intervals, or if you use dino oil, you can change it more frequently if you want.
Stuff like Teflon, or Moly, are additives that can damage your clutch or cause slippage (after all, if you reduce friction you will reduce the ability for the clutch plates to 'lock up' at the recommended RPMs to get you going.
Good Luck.
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
post #6 of 45 (permalink) Old 05-07-2009, 03:50 PM Thread Starter
Super Poster
Castrol makes a Syntec Full Synthetic that is rated at 5W50 that I've been interested in using, but it only listed as SM/SL/SJ/CF, which had me quite worried. Do you think I'm pushing my luck with a 5w instead of a 10w? In my car, this would be a GODsend at just $7 a qt., as we here in Baltimore, Maryland get extremes of weather from single digits to tripple digits (F), sleet in the summertime, droughts in the winter, and basically, the saying "If you don't like the weather wait five minutes" says it all. A 5w50 oil could easily be used year-round here, if the clutch can handle it.
BTW, I'm using a stock Suzuki Filter, for now. Advance sells a K&N, but for now, I'm more comfortable with the stock until I can research the K&N better.
post #7 of 45 (permalink) Old 05-07-2009, 04:25 PM
Super Poster
billbytheway's Avatar
I still say fully synthetic is a waste in a road going vehicle. Use semi synthetic (but it must be the ester based type) and save your money. If you adhere to recommended inrevals semi will be just as good as fully synthetic.
A question from England. Whats dino?
Cheers
Bill
I once concluded a phone call "my name is Bill by the way" and it stuck!
billbytheway is offline
post #8 of 45 (permalink) Old 05-07-2009, 04:36 PM
NormanB's Avatar
Dino (As in Dinosaur) = traditional oil - as opposed to all this synth/semi synth marlarkey.
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
post #9 of 45 (permalink) Old 05-07-2009, 05:43 PM
Super Poster
Norm I should have guessed. Suppose I'm a bit of a dinosaur at 54! (I'm now taking care not to push the Burgman uphill into the garage! This hernia has been a great holiday.) Bill
post #10 of 45 (permalink) Old 05-07-2009, 06:05 PM
Insane Poster
Here's an interesting read. It may be worth what you paid for it but Dr. Haas is certainly an educated fellow and wouldn't be publishing BS, I wouldn't think.
http://www.bobistheoilguy.com/aehaas/
'06 Burgman 400, '06 Burgman 650 - The GRINerators.....and a '06 Hi-Vis Yellow DR650SE
djb383 is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
03 brake question - probably a newbie question qqssdancer Burgman 400 (pre-2007) 2 07-20-2007 10:45 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
