Burgman won't start!! - Suzuki Burgman Forum
Reply
post #1 of 17 (permalink) Old 01-28-2009, 08:59 AM Thread Starter
IJC
New Member
I need to get to work this morning!! and my always dependable 2008 650 Exec. that usually starts right away will turn over with all of the proper lights lit up but will not start. Any quick suggestions??!!
I have checked some of the fuses but I do not know where the main fuse box is.
Jeff
IJC is offline
Sponsored Links
post #2 of 17 (permalink) Old 01-28-2009, 11:05 AM
Insane Poster
MyWifeSaidYes's Avatar
Re: Burgman won't start!!
MyWifeSaidYes
Iron Butt Association #37830
2009 Burgman 650 Executive - Repo'd Fall of 2010 - Great while it lasted!
Maybe 2014 will be good to me?
MyWifeSaidYes is offline
post #3 of 17 (permalink) Old 01-28-2009, 11:09 AM
Insane Poster
Colchicine's Avatar
The usual. Check:
The side stand is up
The kill switch is not engaged
That one or both brake levers are depressed.
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #4 of 17 (permalink) Old 01-28-2009, 11:11 AM
Jim
Jim's Avatar
Quote:
Does this mean that the engine turns over, but will not start?
Pictures of Modifications and Accessories
Jim is offline
post #5 of 17 (permalink) Old 01-28-2009, 11:20 AM
Insane Poster
your side stand switch has corrosion of some sort on it. clean it and it will start. if not, check your battery wires if they are loose...........larry
06/650
garmin gps/ram mounted on brake resevoir (use it everyday, always on bike, with a ram lock)
tourmaster cortech saddlebags (used on longer trips, works great)
besteem 2012 (black) top box (great add on)
michelin/r, oem/f
givi windscreen (best upgrade yet)
ram mount cup holder (works great)
larry is offline
post #6 of 17 (permalink) Old 01-28-2009, 02:12 PM
Insane Poster
...will turn over with all of the proper lights lit up...
I would take this to mean that the starter motor is turning the engine, but the bike is not starting. That would mean all the safety interlocks are closed (key to 'on', kill switch to 'run', sidestand up, brake lever held in).
So then the question is "What's wrong with the ignition?" Out of fuel? Water in the fuel line? Lack of spark?
Does the engine sound like it tries to start, or does it just spin?
MyWifeSaidYes
post #7 of 17 (permalink) Old 01-28-2009, 03:12 PM
Insane Poster
Buffalo's Avatar
I had the same problem with my 07 Exec shortly after I bought it. Took it to the dealer and the service manager was able to get it started by cranking it while holding the throttle wide open. I would suggest you put it on the center stand then hold the throttle wide open and crank it for a couple of seconds. Can't hurt and might work for you.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,929 miles
"Little Blue" 2006 Blue 400S - 47,595 miles
Buffalo is offline
post #8 of 17 (permalink) Old 01-28-2009, 06:44 PM
Insane Poster
Dave_J's Avatar
Quote:
That worked for me too. DaveJ
Dave_J is offline
post #9 of 17 (permalink) Old 01-28-2009, 08:16 PM
JohnK's Avatar
Same thing here on my 06 once. I think it was due to some condensation after the bike sat for a week during a major temp change with partially filled tank. It finally started after the wide open throttle trick and has not repeated itself. I have gotten into the habit of trying to ensure it has a full tank if the temp are going to vary widely, especially form hot to cold.
JohnK
AN650A K6 (lifetime avg. 55 mpg)
JohnK is offline
post #10 of 17 (permalink) Old 01-30-2009, 11:03 PM Thread Starter
IJC
New Member
Thanks for the input! After going through all of the fuses , putting the sidestand up and down, and cycling the kill swich the engine continued to turn over but still no ignition. I finally put it on the center stand and tried to start one more time. The engine showed a little sign of ignition and by opening the throttle just enough the engine finally started.
One hour late for work but the Burgman still got me there. The problem has not repeated itself and the 650 is back to starting normally.
IJC is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Burgman won't start help! rliou Burgman 650 36 02-03-2017 11:38 AM
07 Burgman won't start Shoe Burgman 650 7 04-10-2013 02:37 PM
Will not start! 04 Burgman 400 stunna Burgman 400 (pre-2007) 5 02-11-2011 10:03 PM
Burgman won't start! Why? byronhchan21 General Discussion 5 12-25-2008 10:42 PM
Start with burgman 400 or 650? koryo Newbie Questions! 30 10-04-2008 09:21 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
