Wiring front turn signal/running lights - Suzuki Burgman Forum
Reply
post #1 of 11 (permalink) Old 01-26-2009, 07:54 AM Thread Starter
Insane Poster
paulcbrowne's Avatar
I have everything I need to make my turn signals into running lights as well as doing off-bright-off for the turn signal -- amber LED bulbs, the Magic Blinkers, and load balancing resistors.
My question is how to get the hot wire into the mirror housing or else tap into the front flasher wire without removing the mirrors ad maybe other tupperware. I can't figure where the turn signal wiring is inside the tupperware and can't see how to fish a hot wire into the turn signal space on the mirror. Parts are small enough to mount behind the turn signal lens/assembly, but would prefer to connect inside the bike.
BTW, I'm using LEDs that are quite bright, but they draw only about 3 watts each when on vs. 27 watts each for 1156 or 1157 bulbs.
Shepherdstown, WV USA
paulcbrowne is offline
Sponsored Links
post #2 of 11 (permalink) Old 01-26-2009, 08:42 AM
Insane Poster
Colchicine's Avatar
Re: Wiring front turn signal/running lights
You may not have read everything ... search for "rollingbones" as he has posted pictures and a full description of how to run the wire in an Exec mirror. Sorry I don't have the link on hand. I did it the hard way and removed the mirrors. If you do find it, post it here. Good luck!
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #3 of 11 (permalink) Old 01-26-2009, 12:11 PM Thread Starter
Insane Poster
This looks like the link that you referred to: viewtopic.php?f=19&t=21429&p=197413&hilit=+mirror+ exec+lights#p197413
But, I'm trying a different approach that replacing the single filament 1156 bulb with a dual filament (1157) bulb -- LED 1156 (single contact) LED bulb with the Magic Blinkers and balancing resistor. I was just trying to find where those dang turn signal wires are inside the tupperware.
post #4 of 11 (permalink) Old 01-26-2009, 12:32 PM
Insane Poster
Colchicine's Avatar
You found the post, thanks for digging that up. I'll be sure to add it to my index this time.
Don't be afraid to take the tupperware off. You could probably get to the wires with just the top dash off, but it wouldn't be a bad idea to take off the headlight section either. Just as simple as tracing the wires.
Kory's
post #5 of 11 (permalink) Old 01-26-2009, 06:50 PM Thread Starter
Insane Poster
Ha, stripping off the tupperware can't be any worse that on my BMW K1200LT that I used to strip down annually! Just hoped to avoid the "learning experence" on the Burgman. It's a bit hard to trace the wires and they changed the '08 harness and routing as I examine the manual. Now, if that wiring diagram wasn't so small!
post #6 of 11 (permalink) Old 01-28-2009, 08:53 AM Thread Starter
Insane Poster
I found the two plugs for the right and left turn signals. I had removed the upper dash with the small cubbies, handlebar covers, but what really helped was taking off the nose piece above/between the headlights. It comes off very easy after -- there are 5 straight-in push connectors that can be pried up easily with a screwdriver and a piece of cardboard to keep from scratching the paint. I had taken off the windshield but that was unnecessary.
The turn signal plugs are cabled tied to another set of wires on the crossbar that easy to see with the nose off. The plugs for the turn signals have an oval cross-section. The other wires have a squarish connector -- assume those are for the mirror motors. Left turn signal is black for hot and black/white for ground. Right turn signal is light green for hot and black/white for ground.
I found it easiest to see and disconnect the turn signal plugs after I unplugged and pushed aside all of the other connectors under the removed nose piece.
One thing I did for testing was to use Posi-connectors that could be undone easily, unlike crimp connectors.
post #7 of 11 (permalink) Old 01-30-2009, 06:15 PM
Insane Poster
Rollingbones's Avatar
When I wired mine, I pulled the lamp assembly, fed the wire through the mirror post to under the dash. No need to remove any tupperware; only pull the dash cover. There's a small hole with a rubber plug on top that I popped out to help feed the wire (underneath the rubber dam). I fed the wire to the hole, grabbed it with some small/narrow needle nose pliers and then fed it down and to the space behind the dash. I then wired them to their own switch. I also have a couple of small lights for my controls on the same line. My riving lights have their own switch and line. Here are some pics:
The new lamp socket from Pep Boys
The hole where the plug came from to help with the feed:
The switches:
I hope this helps...Rb
Mark...Rollingbones
2007 AN 650A Executive (Sold)
2008 Kawasaki Vulcan 900LT Classic (Eljay)
I didn't lose my mind...I sold it on eBay!!!
Rollingbones is offline
post #8 of 11 (permalink) Old 01-31-2009, 04:26 PM
Super Poster
I've been to AdvanceAuto and Autozone. Both say the vendor is out of the 84725 socket. Does anyone know of an alternate socket that will work, like for a flat base bulb? Thanks
Mark
markc50 is offline
post #9 of 11 (permalink) Old 03-11-2010, 10:25 PM
TechArtGuy's Avatar
Send a message via Skype™ to TechArtGuy
Just finished up wiring in a set of magic blinkers from custom dynamics. Here's a short vid of how they operate ->Link
I have these paired with a solid state flasher relay as well from custom dynamics.
Two Tone PUFFY seat, Rostra Cruise Control, Projector HID headlights, Tour Tank, Givi E21 Side panniers, passenger extensions, Izuzu backrest, chrome handbars, Powder coated wheels and calipers, DC sport exhaust mod (welded) w/baffle, V3 triton switchback turns, RGB ground effects lighting
- Soon to be offering basic maintenance services.
TechArtGuy is offline
post #10 of 11 (permalink) Old 03-11-2010, 10:41 PM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
Look for the 'Mystery Molex Connectors' mentioned in a new thread.
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Front turn signal conversion to running lights mike1nw Burgman 400 (2007+ model) 0 09-06-2012 02:19 PM
Running Lights / Turn Signal ????? doc exec Burgman 650 1 03-13-2009 07:46 PM
Turn Signal Running Lights dabimf Burgman 650 2 04-03-2005 02:13 PM
TURN SIGNAL RUNNING LIGHTS JD Feedback for Suzuki 3 12-06-2004 11:59 AM
turn signal/running lights aehansen Burgman 650 4 01-09-2004 05:45 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
