Fuel mileage poll overall average (US gals.) - Suzuki Burgman Forum
View Poll Results: What is your overall combined average? (US gals.)
Pre K5 650 45 - 50 37 12.98%
Pre K5 650 40 - 45 14 4.91%
Pre K5 650 40 or less 4 1.40%
Pre K5 650 50 - 55 29 10.18%
Pre K5 650 over 55 1 0.35%
K5 + 650 40 or less 8 2.81%
K5 + 650 40 - 45 33 11.58%
K5 + 650 45 - 50 73 25.61%
K5 + 650 50 - 55 75 26.32%
K5 + 650 over 55 11 3.86%
Voters: 285. You may not vote on this poll
Reply
post #1 of 39 (permalink) Old 07-26-2008, 08:12 PM Thread Starter
JohnK's Avatar
Jim last did this poll almost 3 yrs. ago, just prior to the intro of the OD and remapping of the ECM and throttle bodys.
After talking with him and others I thought about redoing it for an update that people could refer to for comparison.
Yes, there are a lot of things that can influence mpg, but we're just looking for more accurate overall figures in the poll.
I do encourage you to list in your text anything you think may help others in apples to apples comparison.
IE: Driver size/wgt., shields, saddlebags, tire pressures, etc.
JohnK
AN650A K6 (lifetime avg. 55 mpg)
JohnK is offline
Sponsored Links
post #2 of 39 (permalink) Old 07-26-2008, 08:18 PM Thread Starter
JohnK's Avatar
Re: Fuel mileage poll overall average (US gals.)
Driver= 155#
OEM shield
TOP case
OEM tires set for two up pressures
Conservertive driver 95% of the time in auto mode
87 Octane fuel with little to no ethanol
Worst mpg 48.9 with ethanol in stop and go city and construction zones with cooler climate
Best mpg 64.3 cruising secondary roads in warm weather, no ethanol at speeds 45 - 60 mph
JohnK
JohnK is offline
post #3 of 39 (permalink) Old 07-26-2008, 09:53 PM
Insane Poster
trebor's Avatar
2004 AN650
Driver = 235 lbs.
Givi shield.
Givi Maxia top case = 52 liters.
High up backrest.
No OD.
87 Octane fuel 99% of the time, never any ethanol junk.
Automatic mode 99.8% of the time as thats how I attain my best fuel mileage.
Bridgestone Batlax TH01's front and rear.
Air pressure front 35-36 lbs, rear 41-42 lbs. Single or 2 up.
Worst fuel mileage 47-48 per imperial gallon, combined city and highway or using POWER mode and under cooler temps. I never calculate MPG's in U.S gallons, its either liters per 100 kms or miles per Imperial gallons.
Best fuel mileage 54-56 per imperial gallon, mainly highway or country roads 50 to 65 mph, rpm's 3500 to 4500. I never calculate MPG's in U.S gallons, its either liters per 100 kms or miles per Imperial gallons.
Curiously very little difference in fuel economy my riding single or with my 135 lbs wife riding pilion.
Normally my riding style is relaxed and easy, get there 5 minutes later, but get there in one piece.
For the purpose of this poll I performed the conversions to U.S gallons:
Worst would be = 40 to 42 mpg per U.S gallon.
Best would be = 47 to 49 mpg per U.S gallon.
Life is like a coin, you can spend it any way you want, but you can only spend it once!
AirHawk Medium
Alaskan Leather sheep skins
BrakeAway Cruise control
Grip Puppies
Jac Vinson Backrest
Givi Windscreen
Givi Maxia 52 with lights
Nelson-Riggs CL-850 saddle bags
trebor is offline
post #4 of 39 (permalink) Old 07-26-2008, 10:13 PM
Active Member
200lbs
Clearview large
46 mpg overall
2007 650 Exec, Kurys, Brakeaway, Clearview large, Russel Day Long, Ram reservoir mounts, Nolan NCom, Zumo 550
crewzr is offline
post #5 of 39 (permalink) Old 07-26-2008, 11:47 PM
Ken
Insane Poster
03 Model, blue & well waxed
my weight 190#
TP front 34PSI Rear 39
87 octane and 10% ethanol (ethanol does decrease MPG about 3 mpg)
Clearview large
Bestram Top Box
Mostly flat freeway and state roads with rolling hills @ twisties
I wish I could say 60+MPG but it is 50-51 smiles solo and 48 when 2 up
Ken
Blue 2003 Burgman 650
Ken is offline
post #6 of 39 (permalink) Old 07-27-2008, 12:32 PM
Insane Poster
LeDude's Avatar
Scooter..........................: Stock 04 standard 650 with a top box.
Rider weight....................: 190lbs (solo rider)
Tires pressures.................: 40 psi Front, 42 psi Rear (OEM Bridgestones)
Stop & Go City driving mpg...: 45-50 mpg (speed 05-55 mph)
Non stop driving mpg..........: 55-65 mpg (speed 35-85 mph)
Worst mpg......................: 42 mpg
Best mpg........................: 65 mpg
Fuel type........................: 87 octane
Shifting mode..................: Automatic 99% of the time
Power mode....................: Hardly ever used
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #7 of 39 (permalink) Old 07-27-2008, 02:16 PM
Ken
Insane Poster
LeDude, I notice your weight and mine are the same and you are riding a non OD as well but your MPG is much better than mine. I notice that you are running higher air pressures than I do. Could that make such a difference in MPG? Does running higher pressures make the tire wear more in the center? I may try what you are running and see if it makes a difference. Hopefully those pressures won't change the handling of my scoot
Ken
Ken is offline
post #8 of 39 (permalink) Old 07-27-2008, 09:56 PM
Insane Poster
LeDude's Avatar
Ken,
You can always give it a try and see if it is going to make a difference for you.
I have been running these same pressures ever since I bought my Burgy so I couldn't tell you anything different.
I always check the side wall on my tires to see what the maximum psi limit is and usually either run it at that or one or two psi below that depending on the bike. The Bridgestones have a 44 psi max limit.
For my Burgman the 40 psi front and 42 psi back have worked really well. Bike still feels very responsive and doesn't float or lose traction at all.
I haven't experienced any cupping or uneven wear on my tires, and I have been getting close to 15k miles out of my rear tire and probably around 21k out of the front tire.
I check my tire pressure twice a week and after each bike wash.
I have my rear suspension set to 3.
LeDude is offline
post #9 of 39 (permalink) Old 07-27-2008, 11:08 PM
Active Member
Steve_B's Avatar
Scooter..........................: Stock 07 standard 650
Windshield......................: Givi
Rider weight....................: 360lbs (solo rider)
Tires pressures.................: 40 psi Front, 44 psi Rear (OEM Bridgestones)
Stop & Go City driving mpg...: 45-50 mpg (speed 05-65 mph indicated)
Non stop driving mpg..........: 50-58 mpg (speed 35-75 mph indicated)
Worst mpg......................: 43 mpg
Best mpg........................: 58 mpg
Started playing with manual mode for my commute to and from work, seems to cause my mpg computer to climb faster.... but have not done enough to be conclusive...
Steve_B is offline
post #10 of 39 (permalink) Old 07-28-2008, 02:17 AM
Super Poster
I have an '06 650 Exec:
Rider: 180#
Commute: Secondary roads, 35-50mph average, occasional traffic light etc.
Stock: Everything except the PCIII & GBat battery.
PCIII: Got this to eliminate the cough back through the air filter in cooler temps and throttle position between accel & decel. Annoying issue to me.
MPG: Always a constat 50mpg. One trip meter is reset every fill: 50mpg. Second trip meter has @ 4,000 miles: 50mpg.
Miles: Odo is @ 13,600.
The PCII eliminated that nasty cough. I suspect is was a tad lean from factory and as such, inefficient. It also gave a better average mpg and has a small but noticable performance boost - mainly to being a more efficeint air/fuel ratio. If I was after peak air/fuel ratio etc, I'd have her dyno'd but she's good as it is using the stock map.
Cheers,
Leigh
2006 650 Exec - "Booter"
2003 VL 1500 LC - "Elsie"
1986 Cavalcade LX
IBA #24192
50-CC - Coast to Coast under 50 Hours
SS-2000 - 2000 Miles under 48 Hours
BB-1500 - 1500 Miles under 36 Hours
SS-1000 - 1000 Miles under 24 Hours
OneFromOz is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Fuel mileage poll overall average (US gals.) JohnK Burgman 400 (2007+ model) 52 09-20-2011 05:56 AM
average mileage on one tank LuisM Burgman 400 (pre-2007) 13 07-12-2010 06:08 PM
Fuel mileage poll overall average (US gals.) JohnK Burgman 400 (pre-2007) 30 10-21-2008 03:22 PM
Mileage Poll Jim General Discussion 78 04-29-2008 10:22 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
