Passenger Armrests? - Suzuki Burgman Forum
Reply
post #1 of 14 (permalink) Old 07-24-2008, 11:42 AM Thread Starter
Insane Poster
CalvinFold's Avatar
Passenger Armrests?
I found a thread in General, but it kinda went nowhere by the looks, thought I'd try the 650-specific folks:
Looking for a way to give my passenger armrests. The solution here requires fabrication beyond my ability, plus the Givi cases on the Mueller racks prohibit this setup anyway by the looks of it.
What I have to work with:
--No metalworking skills.
--Am capable of assembling, drilling, bolting, and epoxying metal
--Can't cut metal--so anything bolted or glued together has to be off the shelf, or small enough to grind/cut with a dremel tool
--Don't have any friends who weld or a shop I can get to do it (good help is so hard to find...)
--A Givi rack with an E52 Maxi case (the case must remain...it's the passenger backrest)
--Mueller racks (so any solution can't extend below the level of the handrails)
--I have no issues modding the E52 or the Givi rack as long as it does not compromise the function and integrity of either. E52 must at least be removeable, since for solo use I switch to a smaller V46.
What I tried:
I had thought to strap some duffel bags to the grabrails above the Givi's on the Mueller racks, but that turned-out to inhibit access to the sidecases too severly.
Ideas:
No idea how to accomplish this with off-the-shelf components (or even ordering stuff from McMaster-Carr), but if one of you is clever:
--Bolting armrests to the seat somehow via the couple of bolts up underneath. Somehow make a bracket and find some armrests that would work. Trick is I don't know where to start on the bracket nor what armrests would suit the project.
--Bolting armrests to the Givi rack or the E52 itself. The link above shows what looks like a plate under the rack...which is perfect if you have the fabrication abilities...I don't. And I suspect the E52 would not appreciate the strain of armrests bolted to it.
What I need:
Something for my wife Patricia to rest her arms on and at least lightly lean on with the chance she might nod-off and put her whole weight on them momentarily or put weight on them while mounting/dismounting.
She's hypothyroid--which to you folks means while she loves to go on rides, I ride smoothly and lazily enough that she often dozes-off from simple fatigue. The PC800 didn't have armrests, but she managed to stay upright while sleeping lightly, and usually tilted forward if she fell too deeply asleep (clunk!). But once in a while she'd drift sideways, and as I go into a turn she'd abruptly wake-up from leaning-over, slightly unsettling the bike. No real danger, and I've learned to wake her up before she gets "that asleep," but as a present for her, I thought some kind of armrest contraption would be sweet.
(I know, I know...speeches from the safety folks about sleeping passengers...we understand the risks...)
THANKS!
Kevin(aka "CalvinFold")
CalvinFold is offline
Sponsored Links
post #2 of 14 (permalink) Old 07-24-2008, 11:52 AM
Jim
Jim's Avatar
Re: Passenger Armrests?
I'm kinda in the same boat, I thought of some type of arm rest. My wife seemed to adapt to her "Power Naps", usually 10 minutes at a time. She uses her legs to stabilize while riding, and then it's a smooth, or just a boring road. It seems more frequent, now that I installed the Fehling sissy bar. The additional height, allows her to also use her back to help stabilize.
Perhaps something could be designed to mount on the Fehling backrest. I'm sure it could handle the stress.
Pictures of Modifications and Accessories
Jim is online now
post #3 of 14 (permalink) Old 07-24-2008, 12:55 PM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
With some fiberglass cloth, plastic wrap, resin and some foam forming, I think you could fabricate about anything and make it custom, however, finding mounting places without going to a trike conversion might be a problem. Of course the trike conversions provide the best stability and seating with armrests, though. I've seen many custom things made from fiberglass, from seats, to furniture, to custom fit speaker boxes for vehicles, so you might experiment and see. You can start with prototype wooden forms, then cover with foam and wrap with fiberglass....and you can be creative.
As for dozing off, my wife has no thyroid and she takes synthroid, which is for hypothyroidism or no-thyroidism, so your wife may need to see the doc to up her medication, as dozing off isn't really an issue if meds are right. Been there, done that.
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
post #4 of 14 (permalink) Old 07-24-2008, 01:10 PM Thread Starter
Insane Poster
CalvinFold's Avatar
Quote:
She's tried, problem is she's been to three doctors who all say that since her numbers are normal, she should be fine (the "it's all in your head" problem) or "you'll get used to it in 2-3 years and feel better."
Her thyroid was nuked...she has one, but it essentially doesn't function (she was hyperthyroid...some "cure").
Other problem is, she doesn't respond to artifical thyroid, and near as we can tell, the "real" stuff she has to take is much less effective, dose changes take months to show change, etc.. Not to mention pricey because it's harder to get the effects consistant when you're useing ground pig's thyroid (**** they smell nasty).
Back on topic, I'm not likely to be any better making my own fiberglass bits than I am at welding...mechanical talents have always eluded me beyond the basics. I'm more a technology guy.
post #5 of 14 (permalink) Old 07-24-2008, 02:04 PM
Insane Poster
convertfromVespa's Avatar
I read somewhere in burgmanusa that someone adapted a goldwing backrest and arm rests to their 650. I think that I saw it in one of the many links to using an izuzu headrest as a backrest.
I hope that helps.
gallery:
convertfromVespa is offline
post #6 of 14 (permalink) Old 07-24-2008, 06:16 PM
Insane Poster
seatec's Avatar
It was me that has the GW backrest and I added Kurtakyn arm rest, wife says its very comfortable, you can see pictures on my trike site in my gallery. If you have a Corbin seat it makes it easier to mount the GW back rest. The arm rests are very heavy and they need a lot of support, some one put them on a Givi box a while back, they are also in gallery on my web site, just check through the members pictures. Wayne
seatec is offline
post #7 of 14 (permalink) Old 07-24-2008, 06:22 PM
Insane Poster
seatec's Avatar
look in sonny 1639 gallery to see how he added the armrests, looks easy enough to do. on www.burgmantrikes.com Wayne
seatec is offline
post #8 of 14 (permalink) Old 07-25-2008, 10:33 PM
Turbo Poster
wspollack's Avatar
Quote:
Originally Posted by seatec
look in sonny 1639 gallery to see how he added the armrests, looks easy enough to do. on http://www.burgmantrikes.com Wayne
Seatec,
Sonny 1639 ought to considering selling a kit, consisting of that base bracket (looks like a substitute for the Givi product) and those side brackets and the armrests. I'd be interested, if the price were "reasonable" (whatever that means).
And, if a fabricated mod could include a better backrest than that high, little, Givi thing that sits near the top of the E52, I'd be really interested.
Regards,
Bill P.
2008 Exec:
Givi E52; AdMore lights; CustomLED flasher; Clearview; SpeedoHealer; Motolights; Running-lights mod; Powerlet socket; MCL RAM covers; G2 Throttle Tamer
2007 Exec [Sold in '12]:
Givi E52; Clearview; MC Cruise; SpeedoHealer; Motolights; Stebel air horn; Running-lights mod; Oznium LEDs; Powerlet sockets; MCL RAM cover; SW-Motech riser; Manic Salamander bar ends; Yoshimura exhaust; G2 Throttle Tamer
Gallery:
wspollack is offline
post #9 of 14 (permalink) Old 07-26-2008, 06:12 AM
Insane Poster
seatec's Avatar
I was thinking of the same thing about a bracket for the Givi with armrests added. On my next trike body I plan to have a e 52 givi with GW back rests and arm rests all as one unit which I take off when Im alone, would work on bike I think if it does not need supports to body , because armrests are so heavy. I may make aluminum arm rests Wayne
seatec is offline
post #10 of 14 (permalink) Old 07-26-2008, 07:12 AM
Super Poster
Godzilla's Avatar
This a photo of the armrests on one of our scooters. I have about the same thing on the Burgman. I purchased a piece of pipe that was about 12' long and curved on both ends. I cut the ends off and welded them onto the bumper to provide armrests.
k3 650, Givi bags, humpbag, Happy Trails panniers and topbox. Full bumper,sissybar. 4.5 aux. tourtank, Garmin 60Scx and a coffeecup holder.
Godzilla is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Anyone know of Armrests for the 650 timnizza Burgman 650 14 09-24-2015 04:48 PM
Passenger armrests? mrbongo General Discussion 8 10-12-2011 02:38 PM
Chrome World swing out passenger armrests Charles Creech Aftermarket and Accessories 0 05-15-2010 10:43 PM
Burgman 650 Exec Armrests Chillbilly Aftermarket and Accessories 3 07-21-2009 09:34 PM
Armrests? jayhawkdrummer Aftermarket and Accessories 0 02-28-2006 11:31 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
