Occasional backfiring - Page 4 - Suzuki Burgman Forum
Reply
post #31 of 49 (permalink) Old 12-21-2007, 09:29 PM
Insane Poster
................but if the plug wire is not seated, wouldn't that cause a mis-fire rather than a backfire?
'06 Burgman 400, '06 Burgman 650 - The GRINerators.....and a '06 Hi-Vis Yellow DR650SE
djb383 is offline
Sponsored Links
post #32 of 49 (permalink) Old 12-21-2007, 09:52 PM
Insane Poster
Colchicine's Avatar
Quote:
Originally Posted by gunnphiter
It was also determined that single cylinder engines will do this quite normally.
Yes, the 650 have two cylinders. What's your point?
Waldo must have thought your first statement implied that you thought the 650 has one cylinder. The topic is about a 650 (2 cylinders) and you talked about a single cylinder (a 400).
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #33 of 49 (permalink) Old 12-23-2007, 07:54 AM
New Member
A `misfire` is the cause of a `backfire` due to accumulated fuel not being ignited correctly.
AN650K3
Banana is offline
post #34 of 49 (permalink) Old 12-23-2007, 08:25 AM
Turbo Poster
Yup, the 650 is a parallel twin.
When circumstances seem to coincide in inexplicable ways, the Universe is reaching out to help you.
2007 Burgman 650 "Halfabusa"
2008 Subaru Forester Sport in dark gray to match Burgman 650...needs "Halfabusa"?
Previously Owned: 1978 400cc Honda Hawk and 2000 750cc Kawasaki Vulcan
rbparks is offline
post #35 of 49 (permalink) Old 12-23-2007, 12:31 PM
Insane Poster
A `misfire` is the cause of a `backfire` due to accumulated fuel not being ignited correctly.[/quote]
Hummmmm?
djb383 is offline
post #36 of 49 (permalink) Old 12-28-2007, 04:32 AM
New Member
Misfire / backfire
Hummmmm?[/quote]
Does `Hummmmm?` mean that you do not understand the difference between the two and would like me to explain the difference in more detail.
Or, are you just having a think about it ?
They are two distinctively different conditions.
AN650K3
Banana is offline
post #37 of 49 (permalink) Old 12-28-2007, 09:38 AM
Insane Poster
Yep, I'm curious to know your definition of 'backfire' and a 'misfire'.
djb383 is offline
post #38 of 49 (permalink) Old 12-28-2007, 11:11 AM
Insane Poster
Colchicine's Avatar
Sounds like we've got 2 different "English" versions, like the words **** from the Simon Evans days!
Kory's
post #39 of 49 (permalink) Old 12-28-2007, 11:46 AM
Insane Poster
.....................or is someone being a twit.
djb383 is offline
post #40 of 49 (permalink) Old 12-28-2007, 01:35 PM
New Member
Misfire / backfire
I`m sure you will allow for differences in transatlantic terminology.
A `Misfire`
is an event that occurs within the combustion chamber of an internal combustion engine when the fuel/air mixture fails to be ignited by the spark plug (in the case of the Burgman we know that this is due to a lose plug cap). A `Misfire` produces no sound.
Do not confuse with `Detonation` of the fuel / air mixture which is also an unwanted synario that does produce a sound. (I would be more than willing to define detonation, its causes and effects, should you wish me to).
A `Backfire`
is an event that occurs within the exhaust system of an internal combustion engine when the accumulated unburnt fuel / air mixture that has passed into it resulting from the `Misfire` is ignited as the ignition function is restored to the spark plug. The time interval involved is small but sufficient to allow enough fuel/air mix to create a small explosion, which in a modern well silenced exhaust system can be barely audible. The `Backfire` may occur as a single sound or repeated small popping noises.
It is the same principle that applies to engines fitted with carbs or injectors.
I hope this will satisfy your curiosity.
Lets not forget the original reason for the start of this topic.
The subject has come up before and the answer is the same, `ensure your plug caps are fitted properly`
Regards,
Banana
[/b]
AN650K3
Banana is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Backfiring? IJC Burgman 650 20 08-20-2008 10:36 AM
Backfiring on the 400 miket Burgman 400 (pre-2007) 24 07-20-2007 08:18 AM
occasional backfiring creed3900 Burgman 400 (pre-2007) 13 07-03-2006 08:53 AM
Occasional backfires on my 400... Tomx Burgman 400 (pre-2007) 5 05-22-2006 11:13 AM
Backfiring Ev Brewer General Discussion 13 09-13-2005 07:20 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
