Think I killed it. - Suzuki Burgman Forum
 29Likes
Reply
post #1 of 40 (permalink) Old 05-05-2017, 09:12 AM Thread Starter
Turbo Poster
Tromper's Avatar
Unhappy Think I killed it.
Weelll I don't think that the 650 is supposed to spit exhaust out the oil in spout if ya run it without the cap on.
I turned it on a couple nights ago since I'd left the seat up. thought I'd just charge it that way, but got distracted.
By the time I got back to it there was some coolant on the floor and it had killed.
Not sure if the fan just didn't kick on or if something else or ? The valves were a bit marginal but in spec about 6k miles back. Could be an exhaust valve tightened up a bit too much then burned I dunno.
Regardless I'm trying to figure if it's just a valve or two, the head or if I should just look for a used motor, or even another bike.
My first thought would be to part it (good CVT etc) junk the remainder, & get something else, but it would be kind of a pity, this one does have the fancy cruise control, but does have some orange peel so the cosmetics ain't great (I could sand that out too of course).
Any thoughts on the matter would be appreciated.
2k7 B650 "Ohanzee"
2k8 SYM HD200 "Indigo"
2k6 Gray B650XR "Grau Geist" - Gone
Tromper is offline
Sponsored Links
post #2 of 40 (permalink) Old 05-05-2017, 09:15 AM
Insane Poster
AlaskaGuy's Avatar
I have no idea what you are trying to say.
AlaskaGuy is offline
post #3 of 40 (permalink) Old 05-05-2017, 09:31 AM
Super Poster
Sandspike's Avatar
I think he said he wants a new ride and needs a good excuse to give the wife. So he needs to know from us if it sounds good. Sound move. ��
Common sense, the least common of the senses.
Sandspike is offline
post #4 of 40 (permalink) Old 05-05-2017, 09:39 AM
Insane Poster
AlaskaGuy's Avatar
Quote:
Oh. Well, he should just tell her that his girlfriend wrecked his motorcycle, so he needs a new one.....
mikeyMarine, smifff and SgtRV like this.
post #5 of 40 (permalink) Old 05-05-2017, 10:40 AM
Super Poster
Garage
Well, if you run it with the oil cap off, then the crankcase gasses will go in and out of the oil filler every time the pistons go up and down, at a higher velocity than the intake and exhaust (higher because the hole is smaller than the intake manifold or the exhaust pipe). The air in the crankcase has to go somewhere when the pistons come down, and the easiest way out is the oil filler. And there's oil splashing around, so of course it will spit a bunch of oil out in a mist and drops.
Just put the darn oil cap back on. If you're worried about blow-by, that's not the way to measure it; check the compression with a compression gauge. If the compression is OK and there aren't any new noises, then just fill the coolant back up, burp it and ride.
Squeazel is offline
post #6 of 40 (permalink) Old 05-05-2017, 10:47 AM
Turbo Poster
sirkitrider-2's Avatar
Quote:
needs a new one........ wife, bike or girlfriend??
Sirkitrider
Loadtoad and SgtRV like this.
John 3:16
sirkitrider-2 is offline
post #7 of 40 (permalink) Old 05-05-2017, 10:55 AM
Turbo Poster
Well lets not flog Tromper to much since he is a Turboposter here.........BUT a little punctuation would be helpful in comuiekating ......
Also, what year model? How many miles? Please re-post with a clearer explanation of what happened and I bet somebody will be able to offer very helpful response.
Sirkitrider
John 3:16
post #8 of 40 (permalink) Old 05-05-2017, 10:57 AM
Insane Poster
E.D.'s Avatar
^ DITTO on what Squeazel said. Just fill the fluids back up and put the caps on correctly and see how it runs. Why were you running it without the oil filler cap on anyway? If you run it without the oil filler cap on, of course oil is going to splash out of it. What are we suppose to make of your post? Just fill up the fluids and put the caps back on. Give us more information about the bike and what you want.
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #9 of 40 (permalink) Old 05-05-2017, 11:02 AM
MJR
Insane Poster
MJR's Avatar
Agreed.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650, Yoshi Carbon/Stainless Exhaust, Bazzaz Z-Scoot Fuel Control
'06 Oort Gray Burgman 650 rebuilt/upgraded CVT
'06 Oort Gray Burgman 650 another parts bike or project, CVT int failure
'05 Sonic Silver Burgman 650 body damaged, stripped down/rebuilding back up on hold
'03 Space Blue Burgman 650, rebuilt/upgraded CVT with Polish adapter
'03 Space Blue Burgman 650 parts bike, failed CVT splines/brg
www.gotgroceries.net
MJR is offline
post #10 of 40 (permalink) Old 05-05-2017, 11:21 AM
Insane Poster
Quote:
Originally Posted by sirkitrider-2 View Post
needs a new one........ wife, bike girlfriend??
Sirkitrider
yes
hotdogdavis2 likes this.
doctorate dietary medicene, graduate suma cum laude, Ima eta pi
laugh at yourself, everyone else is
mikeyMarine is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Beans can get you killed Rustydust Jester's Court 4 12-25-2013 08:52 PM
Too many Killed....... mernst Safety Tips and Ideas 4 08-24-2008 01:18 PM
my friend Killed PaPa smurf The Tavern 3 08-11-2007 12:05 AM
Killed a squirrel robertnt The Tavern 12 09-24-2005 12:09 AM
Killed some links Pete General Discussion 0 04-29-2005 04:21 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
