Speedometer error reports - Suzuki Burgman Forum
 6Likes
Reply
post #1 of 15 (permalink) Old 04-15-2017, 09:42 PM Thread Starter
Active Member
Blacktruck's Avatar
Send a message via Yahoo to Blacktruck
I recently picked up a 17 model 650 and after my first 1K of riding, I'm curious about the accuracy of the speedermeter. So far according to the fuel pumps (which we have to accept as accurate) and the odometer (which seems okay) I am getting just a whisker over 50 MPG. According to what I read this is about a normal figure. The mileage on the bike and corresponding distance to seem to be what I had before on another bike (not verified with GPS) but I am more concerned with the speed. After all of that here is my question. What does everybody else see on the newer models for speedometer error? GPS is on the list of things to get but curious until then.
Blacktruck is offline
Sponsored Links
post #2 of 15 (permalink) Old 04-16-2017, 08:03 AM
Turbo Poster
wspollack's Avatar
Quote:
1) I don't know about the latest models, such as yours, but I owned a 2007 Exec and now own a 2008 Exec. Both of those, to the nearest tenth of a percent, were/are reading high on the speedometer by 9.2%. This was verified by using GPSs, level and straight highway cruising, attempting to keep the throttle steady (typically at about 70mph -- the higher your steady speed, the easier it is to get accurate readings, i.e., the absolute number sizes in the differences will be larger).
I'm talking without any real knowledge, but I'd be surprised if the newer models were a much better reflection of reality.
2) Speaking of GPSs, if you have a smart phone you can check this now. Lot of free GPS apps. If not, check it when you get your GPS.
3) There's an old thread on speedometer correction that's seen some very recent posts, as well: Speedohealer installed on 2013 B650
You might want to make some time to read through that thread (or others like it).
4) Having daughters in NC and TX (I'm in NY), and having ridden to both, on multiple bikes, I often find myself on boring superslab runs. I have confirmed, by using different GPSs (and on one bike a very carefully configured bicycle computer) that the Interstate mileage markers are dead nuts on, in all the states I've checked.
They make it easy to check odometer accuracy, maybe easier than checking with a GPS (which will have their own tiny inaccuracies, depending on sampling rate, as you go a tiny bit farther in curves than they would note). As long as you pick a mile marker that has not possibly been altered slightly -- e.g., by bridges, on- and off-ramps, come to mind -- and then ride, say, 20, or 30, etc., miles, noting your odo reading at the start and end, you can easily check its accuracy. I've done this several times for nice, even, 100-mile chunks (without pulling off at a rest area, or otherwise interrupting the trip).
5) Hopefully someone with a new model like yours will chime in here, with the exact answer to your question. I don't imagine it will vary much within a given model year, although particular tire brand and changes in tread depth may affect that last tenth of a percent.
Regards,
Bill P.
2008 Exec:
Givi E52; AdMore lights; CustomLED flasher; Clearview; SpeedoHealer; Motolights; Running-lights mod; Powerlet socket; MCL RAM covers; G2 Throttle Tamer
2007 Exec [Sold in '12]:
Givi E52; Clearview; MC Cruise; SpeedoHealer; Motolights; Stebel air horn; Running-lights mod; Oznium LEDs; Powerlet sockets; MCL RAM cover; SW-Motech riser; Manic Salamander bar ends; Yoshimura exhaust; G2 Throttle Tamer
Gallery:
wspollack is offline
post #3 of 15 (permalink) Old 04-16-2017, 09:49 AM
Super Poster
Sandspike's Avatar
Push it up to 85 and you will get 39mpg and half a quart of oil will migrate from the engine to the transmission. It's amazing!
Dave_J likes this.
Common sense, the least common of the senses.
Sandspike is offline
post #4 of 15 (permalink) Old 04-16-2017, 11:09 AM
MJR
Insane Poster
MJR's Avatar
The speedometer and odometer have different inaccuracy percentages, at least they do on my '03. Check them both, I was surprised to find that out. The odometer is more accurate possibly due to some legal reasons. The speedometer may read higher to give the feeling of faster acceleration. But as wspollack said I doubt the newer ones are more acurate.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650, Yoshi Carbon/Stainless Exhaust, Bazzaz Z-Scoot Fuel Control
'06 Oort Gray Burgman 650 rebuilt/upgraded CVT
'06 Oort Gray Burgman 650 another parts bike or project, CVT int failure
'05 Sonic Silver Burgman 650 body damaged, stripped down/rebuilding back up on hold
'03 Space Blue Burgman 650, rebuilt/upgraded CVT with Polish adapter
'03 Space Blue Burgman 650 parts bike, failed CVT splines/brg
www.gotgroceries.net
MJR is offline
post #5 of 15 (permalink) Old 04-16-2017, 11:49 PM
New Member
I have a 13 and the speedometer is 10% optimistic and the odometer is out too but not as much. Haven't verified odometer against GPS or mile markers, but riding with a buddy who owned a BMW GT650, my tripometer would read a few more miles than his. He has since dumped the BMW and got a 17 Burgman 650 and his speedometer reads the same 10% as mine. Tripometer readings are now the same. His speedometer readings on the BMW were closer to actual, but still optimistic by about 2%.
Another good free smart phone app to check speed and usually easier to read, are the heads up display apps. I use an android app called DigiHUD that has a large digital readout that will display correctly or will display in reverse for heads up in a car.
Ride save, Kev
ScootinKev is offline
post #6 of 15 (permalink) Old 04-19-2017, 07:35 PM
Active Member
Johnny Web's Avatar
I checked mine against two different gps units, both indicate the Burgman is 9-10% high on the speed. So that 110 mph I mentioned in another post is really only about 98. I have not noticed any oil migration from engine to transmission either.
Johnny Web is offline
post #7 of 15 (permalink) Old 04-19-2017, 08:25 PM
Insane Poster
Dave_J's Avatar
Quote:
And when I was CLOCKED on Lidar at 122 MPH on my 2003 Burgman, I was too Chicken $hit to look at the speedo to see what it was reading.
My 2008's both would get to 115 MPH and did not seem to want to go much faster. This current 2003 has hit 100 MPH maybe 3 times but I do not want to go that fast for some reason. Its been two years-4 days since my last crash.
All my speedos have been between 9 to 10% off and the Odo's were about 3 to 5 % under, confirmed on a 250 mile road trip and the mile markers and google maps saying how far it was.
Dave_J is offline
post #8 of 15 (permalink) Old 04-20-2017, 04:21 AM
Insane Poster
E.D.'s Avatar
This is nonsense that they can't get the speedos right!
With all this electronic stuff that we have nowadays, computers, cell phones, gadgets of all kinds, there is no excuse that these manufacturer's can't make the speedometers to read correctly as they do in out cars! Nonsense!
This is an outrage I tell you!!!
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #9 of 15 (permalink) Old 04-20-2017, 10:46 AM
Insane Poster
Bluebottle's Avatar
Vehicle manufacturers have to abide by lots of local and international regulation and law.
(Construction and use regs, whole vehicle type approval etc)
Speedos must not under-read so they are always made to over-read.
Odometers must never over-read so they always made to under-read.
Bluebottle is offline
post #10 of 15 (permalink) Old 04-20-2017, 01:28 PM
Insane Poster
E.D.'s Avatar
There is no reason that they can't get it right, or at least very close to right. They certainly have the ability to do so.
Cheers!
Dave_J and Blacktruck like this.
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
10% speedometer error! paulcbrowne Burgman 650 20 06-20-2009 08:23 PM
Speedometer error FutureBurgman650 Feedback for Suzuki 3 04-07-2008 06:13 PM
Speedometer error, or is it? artmonta General Discussion 29 03-25-2008 05:37 PM
Speedometer error? WHATEVER! chadrules Burgman 400 (2007+ model) 12 10-23-2006 02:02 AM
Speedometer error Ragman Web Links 0 07-08-2006 06:35 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
