How hard are 650 tires to mount? - Page 4 - Suzuki Burgman Forum
 21Likes
Reply
post #31 of 43 (permalink) Old 03-18-2017, 05:36 PM
Insane Poster
Quote:
Originally Posted by captainfish View Post
Quote:
wait.. is that how you met your eskimo woman?!?!?
aint sayin nottin besides they only take credit cards in nevada
captainfish likes this.
doctorate dietary medicene, graduate suma cum laude, Ima eta pi
laugh at yourself, everyone else is
mikeyMarine is offline
Sponsored Links
post #32 of 43 (permalink) Old 03-18-2017, 06:40 PM
Turbo Poster
captainfish's Avatar
Quote:
Originally Posted by Skunkhome View Post
Get yourself a bar of ivory snow and chop it up ,,,, Ivory snow Bar soap is pure soap. No detergents, totally safe. And slicker than a greased banana peel.
I agree mikey, I don't think we're talking about tires any more.
Dave_J likes this.
Current Owner:
My 2nd 2005 Blue Burgman 650
Previous owner:
1987 Honda Helix
January 2005 Blue Burgman 650
"Blue Lightning"
Photo Gallery:
captainfish is offline
post #33 of 43 (permalink) Old 03-20-2017, 03:14 PM
Super Poster
Tire brand can make a big difference to how easy tires mount on a 650. Pirelli Diablos are a hellishly difficult to mount on the rim, but easy to seat the bead. Michelin Pilot Sports are the reverse. The Bridgestones sit somewhere in between on both counts. Call me stubborn, but I always use three Motion Pro tire levers.
Over the years, I've tried windex, wd40, soapy water and ru-glyde. They all work as lube, but the ru-glyde leaves the least residue and no moisture inside to corrode the rim if the paint is dodgy (on my 650, it is). Technique is SO important with Burger tires. The carcasses don't have the same amount of give as motorcycle tires, so if you're not paying attention, it will take hours to finish. Getting the first side of a tire over the rim lip is generally pretty easy. Its the second side that's the hair-pulling swear-a-thon.
When guides tell you to keep the near side of the tire pushed down into the rim while you work, they mean BOTH beads (top/bottom). What tends to happen when you push the top bead down into the rim, the bottom bead slips up to the other lip, unnoticed. It's virtually impossible to stretch the stiffer scooter tire carcass enough when this happens. Motorcycle tires are more forgiving here, which is why I thought I knew what I was doing before I got the Burg.
What I do is use a ratchet strap to squeeze both beads into the rim so I have that tiny bit of leeway to complete the mounting on the opposite side. The same ratchet strap (get the type without the hooks) can be used to hold the tire around the circumference if the air escapes too quickly while you seat the beads with a compressor. Keep it tightened, but not locked and it will loosen as the tire expands. I'm not a mechanic and no expert, so take the advice with a grain of salt. Good luck!
The Motomaster-Fram-WD40-Slime experiment continues.
Flywheel is offline
post #34 of 43 (permalink) Old 03-20-2017, 05:22 PM
Insane Poster
TheReaper's Avatar
Which ones ? http://www.ebay.com/sch/i.html?_nkw=...&ul_noapp=true
[QUOTE=Flywheel;1503193]Tire brand can make a big difference to how easy tires mount on a 650. Pirelli Diablos are a hellishly difficult to mount on the rim, but easy to seat the bead. Michelin Pilot Sports are the reverse. The Bridgestones sit somewhere in between on both counts. Call me stubborn, but I always use three Motion Pro tire levers. QUOTE]
If young men refused to fight and die , old men would be forced to settle their differences peacefully . TheReaper!
2007 650 Burgman
2008 650 Burgman sold
2006 650 Burgman sold
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
2004 Honda Silverwing 600
2002 Honda Silverwing 600
TheReaper is offline
post #35 of 43 (permalink) Old 03-21-2017, 11:18 AM
Super Poster
Quote:
I use a woodworking clamp to squeeze both the top and bottom bead together. On a particularly tough tire, I'll add a small block of wood along the bottom bead to make sure it's not getting hung up on the rim. The tire irons I use came with a enduro pack from Pit Posse - it's a cordura pack that holds two tire irons and a spare tube and is designed to be attached to a dirt bike or enduro's front fender. I had this on a DR650, but sold the bike several years ago. It came with the two tire irons in it. No name brand, but just thin. Probably the closest ones are the Motion Pro 11 inch Tire Iron (part #08-0006 on Motion Pro's site).
antimatter is offline
post #36 of 43 (permalink) Old 03-21-2017, 04:50 PM
Super Poster
[QUOTE=TheReaper;1503249]Which ones ? http://www.ebay.com/sch/i.html?_nkw=...&ul_noapp=true
These ones: https://www.motionpro.com/product/08-0007 They are curved to give extra clearance around brake disks and allow you to roll over the rim lip with less scratching.
I also use this to break the bead: https://www.motionpro.com/product/08-0439 It works pretty well (use a deadblow mallet), though three levers will serve the same purpose. Less potential for scratching with the plastic wedge though.
Flywheel is offline
post #37 of 43 (permalink) Old 03-21-2017, 04:53 PM
Super Poster
Quote:
Yes sir, that's what was giving me problems for so long--I THOUGHT I had the bottom bead down in the rim, but didn't. I've also used the bead popper to help wedge the tire in too.
Flywheel is offline
post #38 of 43 (permalink) Old 03-24-2017, 01:47 PM
New Member
Philkin's Avatar
Tires
Just following these comments on tires for 650. The prices you're talkin about are ridicules.
Go to Motorcycle SuperStore and buy both front and rear in Shinko tires for less than $100 delivered.
I've been running these tires on Sport bikes for years and they are hard to beat for wear and handling.
Philkin is offline
post #39 of 43 (permalink) Old 03-30-2017, 10:23 PM Thread Starter
Super Poster
Well, I finally got some time this afternoon to mount the rear. It was a stiff little son of a gun, but I didn't really have a lot of trouble.
The rear that I took off looked fine. I couldn't see any weather checking at all. But at 11 years old, I wasn't riding on it.
I had planned to do both of them today, but an old friend texted wanting to bring two of his over to mount from his ZRX, and we got to jawboning and lost track of time. I'll probably get the front Sunday. That's the next day I'll get free. I never knew being retired would require so much time.
Dave_J and mike D like this.
Retired. Finally found something I'm qualified for.
2006 Burgman 650
2013 Yamaha FJR1300
1999 Kawasaki ZRX1100
Charlie Brown is offline
post #40 of 43 (permalink) Old 03-30-2017, 10:45 PM
Insane Poster
Dave_J's Avatar
Besides ReTired meaning tired again, it is a full time job. Watch the moss grow while trying to figure how to grow grass. Watching back episodes of "Fixer Upper". Feeding the squirrels while chasing the crows away. Feeding the Crows while keeping the squirrels out. Keeping track of if its Saturday again today or Saturday tomorrow again.... Its tough.
Dave_J is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
RAM Phone Mount, Extra fingers, 2" Arm, Ball mount w/plate for '06~'13 Burgman 650 They1 Classifieds 9 03-26-2016 01:44 PM
Tires-Hard or Soft Chaplain KC Burgman 650 9 05-17-2013 07:20 AM
Is the 650 hard to Start? Chet_Benson Burgman 650 16 02-24-2011 06:35 PM
Hard Saddlebags - anyone mount these? Darth Vader Aftermarket and Accessories 5 08-31-2005 06:28 PM
How to mount hard side Cases for 650 csachs1 Aftermarket and Accessories 2 11-11-2004 07:33 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
