Cheap Trunk - Page 3 - Suzuki Burgman Forum
 5Likes
Reply
post #21 of 32 (permalink) Old 03-19-2017, 10:52 PM
Insane Poster
TheReaper's Avatar
Quote:
Originally Posted by westnash View Post
I have used the JC Whitney trunk and it was ok but easy to see why it was cheap. If you are going to use it very much or for very long or to carry heavier items, I would always recommend a Givi. There is much difference in price, I realize, but also in quality.
Amen to that brother , stick with the GIVI stuff . The cheap stuff is cheap for a reason .
TheReaper!
E.D. and Mrchips like this.
If young men refused to fight and die , old men would be forced to settle their differences peacefully . TheReaper!
2007 650 Burgman
2008 650 Burgman sold
2006 650 Burgman sold
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
2004 Honda Silverwing 600
2002 Honda Silverwing 600
TheReaper is offline
Sponsored Links
post #22 of 32 (permalink) Old 03-20-2017, 02:02 AM
Insane Poster
E.D.'s Avatar
Quote:
TheReaper!
I can agree with you on that, But I've got the Bestem TBox 929 because it's "good enough for me".
xringracing and Skunkhome like this.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #23 of 32 (permalink) Old 03-20-2017, 11:43 PM
Super Poster
Skunkhome's Avatar
I have a Bestem 929 on the way and it's pretty inexpensive.
Skunkhome is offline
post #24 of 32 (permalink) Old 03-22-2017, 01:33 PM
Insane Poster
TheReaper's Avatar
Quote:
I bought one new on line (Bestem) because a fellow inmate spoke highly of them . I installed it , took it for a ride around the condo complex then immediately removed it . If I remember correctly , it's now on the back of the camo Silverwing I gave to my son to drive for awhile . It rattled like crazy on the slightest little bump in the road , and here in Michigan we have a LOT of bumps in our roads . All that said I've had good experiences with GIVI and SHAD luggage . Do I think this stuff is too expensive , sure I do . But in the long run comparatively speaking it's not . If you take good care of your GIVI or SHAD luggage you can sell it for a pretty good price , so over time it is not all that expensive , again comparatively speaking . About 8 or 10 months out of the year I use my bikes for every thing and the cars and the trucks sit 99% of the time , so I need a lot of luggage . So it depends in the end how much you actually need and use it ?
TheReaper!
2007 650 Burgman
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
post #25 of 32 (permalink) Old 03-22-2017, 03:11 PM
Insane Poster
TheReaper's Avatar
If some one is looking for some good luggage that is competitively priced check these out . TheReaper!
SHAD rack on eBay http://www.ebay.com/itm/Shad-Top-Cas...NY0sZS&vxp=mtr
SHAD 42 top box on eBay http://www.ebay.com/itm/Shad-Top-Cas...38.m2548.l4275
2007 650 Burgman
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
post #26 of 32 (permalink) Old 03-22-2017, 06:21 PM
Active Member
wl7cpa's Avatar
Garage
I just installed the Bestem 929, their biggest, onto my 2014 Suzuki Burgman. It went well. Just added a few washers above the back spacers to fill the gap. Once I ride for a few weeks, I will modify the tupperware to fit back into place. I have no opinion, other than the instructions are very general and skimpy. Most YouTube data is out of date and does not address specifics of the 2014. Bolts holes are not perfectly lined up, and came up with some extra pieces (a couple of brass looking channel rails about 12 inches long x 1.5 inches wide and some bolts). I am guessing this is a modification for another model. For the price, it will do for around town. The thickness of the walls of the case are obviously thin compared to much higher priced units. Since it is easily removable, I will only attach when I absolutely need it to cut down on sun exposure, which would make it brittle and weak.
2014 Burgman 650
24,000 MILES
Daily Commute: 50 miles
wl7cpa is offline
post #27 of 32 (permalink) Old 03-22-2017, 06:26 PM
Active Member
wl7cpa's Avatar
Garage
I agree with Reaper, above, I think it will rattle a lot. With all bolts tight, it still has some play. I will take the first test run tomorrow and re-post. It can be made to wobble by hand. Bumps and gusts should make it rock and roll. You get what you pay for. $145 vs over $300 or more.
2014 Burgman 650
24,000 MILES
wl7cpa is offline
post #28 of 32 (permalink) Old 03-23-2017, 02:11 AM
Insane Poster
TheReaper's Avatar
This is my 2007 , set up like this cost $1,000.00 U.S. . Did I like paying a grand ? Not really but as crazy as this may sound , it's worth every penny
No regrets whatever .
TheReaper!
2007 650 Burgman
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
post #29 of 32 (permalink) Old 03-23-2017, 03:50 AM
Insane Poster
E.D.'s Avatar
TheReaper!
I SEE what your problem was. When you go to lock the Besteem 929 Box onto the mounting plate, just slip a sheet of that thin syrofoam type packing stuff or small bubble wrap under the box, so that it fits tight when you lock it down. That will keep it from rattling, Also put some stuff in it. Mine is full with 2 leather jackets, 2 airhawk seats, 1 helmet, glasses, and a lot of other miscellaneous stuff. My box weighs about 30 pounds.
I had this box on the back of my 400 for 2 years with no problem. Now I've put that same box on the back of my 650, still no problem.
NO RATTLE AT ALL. ITS A GOOD BOX. Bestem 929.
Cheers!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #30 of 32 (permalink) Old 03-23-2017, 12:44 PM
Insane Poster
TheReaper's Avatar
Cheers!
Actually I did the foam thing when I stuck it on the camo Silverwing , it still rattled but not as bad . But if it's working for you or any one who doesn't care to spend a lot of money on GIVI stuff , good for them . All that said the vast majority of riders would rather go the $100.00 Bestem route , than the $1,000.00 GIVI route like I did . I've used the same luggage on several of my Burgmans , before I sell them I take the accessories off and put them on the next one . For me the stock bike is just half the deal , the other half is the luggage , the GIVI windshield , the modified foam and Utopia back rest seat , the handlebar risers , the air hawk cushion ,and the Break-Away throttle lock . When I ride a stock 650 Burgman without all my accessories , truthfully I can't wait to get off of it . All the accessories listed above cost about $1,800.00 , but for me it makes the bike complete and a real joy to ride .
TheReaper!
2007 650 Burgman
2005 650 Burgman
2009 T-MAX
2006 Big Ruckus
2005 Big Ruckus
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
trunk or rear rack to add trunk - how to?? motoring Burgman 650 16 06-15-2012 05:02 PM
Need advice on which trunk and trunk kit is best for 650? rubbersidedown Newbie Questions! 19 04-04-2009 10:35 PM
good looking trunk, cheap and blue! christopher robbins Aftermarket and Accessories 2 01-07-2008 03:14 PM
Trunk release snapped - laptop and purse locked in trunk! edtech2000 Burgman 400 (pre-2007) 3 05-13-2006 03:49 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
