Correct headlight bulb for 2003 Burgman 400? - Suzuki Burgman Forum
Reply
post #1 of 13 (permalink) Old 06-01-2011, 07:03 AM Thread Starter
Active Member
I'm wondering if any of you can verify the correct headlight bulb to replace on my 2003 Burgman 400? I've read a number of threads, and it seems that JC Whitney sells an inexpensive bulb that will work, and have a vibration resistant component! Here is the link that I found:
http://www.jcwhitney.com/h4-quartz-halo ... ilterid=j3
Any suggestions will be appreciated! Santa Fe Bob
BobDorsett is offline
Sponsored Links
post #2 of 13 (permalink) Old 06-01-2011, 09:54 AM
Missed but Remembered RIP.
Duster's Avatar
Re: Correct headlight bulb for 2003 Burgman 400?
Any auto parts store should have H4 light bulbs.
I prefer halogen...about $8/10 each.
If the 'locator-tabs' on the metal base are different
than your original bulbs, just bend them flat with
a pliers....they'll work fine.
It is well with my soul.
'05 Blue Burgman 400 Back rest & Rear carrier
AM/FM/CD XM Satellite receiver Leather laceup grips
Salamander Bar Ends Dual Batteries
BurgmanSeats 'puffy' seat by Cary
N5MVL Amateur Extra
Patriot Guard Rider #56199
Original ride Yellow 2004 Honda Ruckus
Currently 50,000 on 10-11-2015
(\__/)
(")_(")*
Duster is offline
post #3 of 13 (permalink) Old 06-01-2011, 10:53 AM
Turbo Poster
The original bulbs are 35/35 Watts. An H-4 automotive bulb (AKA as 9003) will fit, but you'll have to bend the bottom tabs flat with a pliers to allow it to fit into the Suzuki headlamp assembly.
The original bulbs are very expensive while the car replacements are fairly cheap.
Ray Nielsen, in Minneapolis and going for a ride today!
Gonpher coughie
ray nielsen is offline
post #4 of 13 (permalink) Old 06-01-2011, 02:42 PM
Turbo Poster
Fatjock's Avatar
I agree with the previous posters.
When I had to do mine, after what I had learned on other threads, I went with Silverstars, and just bent the tabs with a small pair of needle-nose pliers.
The whole job was incredibly easy, and didn't take long.
If you search, there is a thread on here with a complete "how-to", including pictures.
Good luck.
I've never done the course on growing up, and I'm too old to start it now!
Iron Horses in my Stable:
1991 Honda ST1100
2001 Honda ST1100
2006 Burgman 400s
The rest are cages.
Fatjock is offline
post #5 of 13 (permalink) Old 06-01-2011, 04:26 PM
Insane Poster
cliffyk's Avatar
Garage
Down here Walmart has a two-pack of the Sylvania standard H4's for $12.00. They work fine with the tabs flattened, much brighter than the OEM lamps.
They draw 9A to 10A on low beam, and worked with the stock 10A fuses, however I replaced them with 15A fuses just to be sure I would not lose the lights out in the middle of nowhere. The wiring is 18ga which in automotive applications is rated for up to a 7 foot run at 15A.
-cliff knight-
cliffyk is offline
post #6 of 13 (permalink) Old 06-01-2011, 08:11 PM
Insane Poster
Scootereno's Avatar
Yes it should work fine. It will draw a little more amperage but not too much for the wiring harness or fuse. As stated above I just go to the auto parts store or Walmart and get some locally for $8-$10 Most all name brand headlights have anti-vibration components and I would prefer not have things like glass headlights shipped to me.
ScooteReno aka Steve-a-Reno
Basically Stock
Sheepskin Pelt
2.1 MP3 Stereo
Averaging 70mpg
Scootereno is offline
post #7 of 13 (permalink) Old 06-03-2011, 10:38 AM
Super Poster
http://burgmanusa.com/forums/viewtopic.php?f=3&t=46576
The bulbs I use are $5.99 each on sale now at HF, and I always have a 20% coupon as well, so after taxes, under $6 and got a free set of cheap screwdrivers with another coupon I had. I just got a new one a couple days ago. I usually right high beam on all the time during the day, so that if that filament burns out, I still have the low I need if actually riding at night. One of the highs has gone out after about a year, so I assume the other will soon. You can see the change from stock bulbs in the pictures at the bottom of the above thread. I also think it looks nice with the blue coating, even when parked it reflects some color, and that goes nice with my blue bike (blue is the fastest ya know )
Josh
2003 Burgman 400
josh is offline
post #8 of 13 (permalink) Old 06-04-2011, 08:34 AM
Insane Poster
cliffyk's Avatar
Garage
I just read through your headlamp post, the 2-wire connector is for the "dealer mode" test tool:
Which looks suspiciously like a SPST toggle switch to me:
-cliff knight-
cliffyk is offline
post #9 of 13 (permalink) Old 06-04-2011, 09:24 AM
Insane Poster
Scootereno's Avatar
Hmmm....So a bobby pin/paperclip can serve as a headlight test tool? Good to know.
Basically Stock
Sheepskin Pelt
2.1 MP3 Stereo
Averaging 70mpg
post #10 of 13 (permalink) Old 06-04-2011, 02:43 PM
Insane Poster
cliffyk's Avatar
Garage
It's not a "headlight" test tool, it places the ECU into a "dealer mode" to make the odometer display trouble codes:
-cliff knight-
cliffyk is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Help! Headlight Bulb is Dim 650TX Burgman 650 4 08-26-2010 11:04 AM
Replacing a burnt out headlight bulb on a Suzuki Burgman 400 Tomx How To 29 09-08-2009 12:21 PM
what headlight bulb should I get? micbergsma Newbie Questions! 6 03-20-2007 08:40 PM
Headlight replacement bulbs for 2003 Burgman 400 ? BobDorsett Burgman 400 (pre-2007) 5 06-20-2005 09:41 AM
headlight bulb flojo100 Burgman 400 (pre-2007) 7 09-07-2004 06:30 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
