Speedo not working - Suzuki Burgman Forum
Reply
post #1 of 15 (permalink) Old 09-05-2010, 10:15 AM Thread Starter
Super Poster
Speedo not working
Hi Guys,
My speedo stopped working a few weeks ago and at first inspection I found a wire (orange) on the connection cable that had is insulation rubbed off and was probably touching the frame. I fixed that but it did not solve the problem. I then took the speedo sensor apart as per some of the advice fro the list and it is not broken, in fact is in very good condition, so it seems that it can only be the odometer itself.
Any other ideas welcomed.
Best Regards
Luis
Suzuki AN 400 2004
Suzuki AN 650 2002 in bits on the garage floor...
LuisM is offline
Sponsored Links
post #2 of 15 (permalink) Old 09-07-2010, 10:20 AM
billmeek's Avatar
Re: Speedo not working
When the speedometer fails, most of the time it's the speedometer rotor (part 21) in this fiche page:
http://www.yamahasuzukiofcoolsprings.co ... 5%2FSK6%29
Several people have just glued the rotor back together. I've had to replace the entire sensor assembly (part 19) once when a broken rotor damaged the sensor too. I don't recall any other causes for speedometer failure on the forums.
Bill
'03 Burgman 400 in blue
'03 Burgman 400 in silver (rebuilt)
"Yes, I ride it all year round. No, I'm not insane. I'm poor. With insane, you get free room and board."
billmeek is offline
post #3 of 15 (permalink) Old 09-07-2010, 12:29 PM
Insane Poster
Buffalo's Avatar
As you say you've checked the sensor rotor and it is not broken, I would guess that the wire you found with the insulation rubbed off shorted out either the sensor or the meter.
The service manual says to test the sensor and if it test good to replace the meter. There is no test procedure for the meter. The manual does list a procedure to test the sensor. It is on page 8-27 of my manual. If you don't have a manual post back and I will type in the procedure.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 130,106 miles
"Little Blue" 2006 Blue 400S - 46,444 miles
Buffalo is offline
post #4 of 15 (permalink) Old 09-10-2010, 03:35 PM
New Member
Mine was recently fixed part was $144.
Delfino 100 is offline
post #5 of 15 (permalink) Old 10-04-2010, 09:18 PM
New Member
Peter Hall's Avatar
Mine crapped out today at 4560 km. Was driving down the highway and it just quit. I took the speed sensor off and a couple of pieces of plastic fell out. I checked the fisch and the magnetic rotor has been replaced by a new part number. It would seem Susuki is aware of the problem and should have a good will warranty for this?
Peter Hall is offline
post #6 of 15 (permalink) Old 10-07-2010, 09:07 AM
billmeek's Avatar
Doubt it. Expect to pay for the part yourself unless you are under warranty.
Bill
billmeek is offline
post #7 of 15 (permalink) Old 10-07-2010, 10:06 AM
Insane Poster
Buffalo's Avatar
Or just do what many of us have done, glue the rotor back together and reinstall it. Mine broke at around 7,000 miles. I glued it back together with epoxy and it is still working fine with the bike now having over 21,000 miles on it. I just put a new front tire on yesterday and I pulled the rotor out to inspect it. It is still looking just fine. I cleaned it up, regreased it and put it back in.
Buffalo is offline
post #8 of 15 (permalink) Old 10-09-2010, 09:31 PM
New Member
Peter Hall's Avatar
OK, so I pulled the wheel off and removed the speedo send unit, no problem there. The plastic end piece that turns the magnet was broken free and spun freely. the magnet itself is stuck to the shaft. I'm going to try gently heating itto see if it will come free. It looks like the old grease had hardened and caused the sender to break. If I can get this fixed, looks like regular greasing will prevent this from happening again. Comment anyone?
post #9 of 15 (permalink) Old 10-10-2010, 11:02 PM
Insane Poster
Buffalo's Avatar
Cleaning and regreasing seems to be working to keep mine going since I repaired it. I've added it to my regular mainenance schedule.
Buffalo is offline
post #10 of 15 (permalink) Old 10-11-2010, 02:25 PM
New Member
Peter Hall's Avatar
Well, good news. I managed to get the magnet unstuck and reglued. It's working for now but the magnet has a linear crack and I don't know how long it will last. the cause of my grief was that the magnet stuck to the center shaft. probably never greased and the old grease hardened causing it to break. Proper maintenance would have prevented this and I'll be doing this on a yearly cycle from now on.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
2003 Burg 400 - speedo not working brap 4 me Burgman 400 (pre-2007) 4 08-21-2012 10:01 PM
Speedo Was Broke But Still Working? Scootereno General Discussion 1 12-18-2011 09:03 PM
Speedo not working, now I know why! fardeenc Burgman 400 (pre-2007) 7 06-06-2010 07:30 AM
speedo stopped working... fardeenc Burgman 400 (pre-2007) 3 03-18-2010 11:42 AM
Speedo not working charlbur Burgman 400 (pre-2007) 8 09-01-2006 10:02 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
