Burgman 400 gvwr - Suzuki Burgman Forum
 5Likes
Reply
post #1 of 14 (permalink) Old 04-07-2017, 12:56 AM Thread Starter
New Member
Burgman 400 gvwr
I currently have a Honda GW GL 1200. but am wanting to downsize & modernize. I am thinking of a 2006 Burgman 400, My concern is what the Max allowable weight is. For 2up riding which will be limited to short local trips may exceed the bike limit. I and my wife are just over 200 lbs each (210lbs) Any one have any first hand advice for me. Thanks in advance.......Vic.
Vic Whorpole is offline
Sponsored Links
post #2 of 14 (permalink) Old 04-07-2017, 12:54 PM
Turbo Poster
xringracing's Avatar
Quote:
Vic, my wife and I are in the same weight range, actually a little more. No problem for the 400. Buy it and roll it!
My wife and I have done 150 miles together.
2004 Burgman 400
xringracing is offline
post #3 of 14 (permalink) Old 04-07-2017, 01:10 PM
Insane Poster
150 miles? It's half of a standard trip -- did you drop the wife midway or something.
xringracing likes this.
Burgman 650 '04 Exec black (too much a scoot)
Last true 400.
Suzuki DL1000. (gone but still most miles)
Bolzen is offline
post #4 of 14 (permalink) Old 04-07-2017, 03:17 PM
Insane Poster
E.D.'s Avatar
You will have no problem riding the Burgman 400 2 Up. I rode with my wife on the back, me 315 pounds, her 225 pounds, that is 540 lbs, PLUS the Top Box on the back loaded with gear add another 30 pounds, for a TOTAL of 570 pounds. The tire pressures have to be inflated to 26 front, 36 rear for Two Up riding. The Rear Suspension has to be set on the highest setting of 7 (normal setting is 3). I set the rear suspension at 7 and leave it there. No need to ever change it. I rode like this for years with a lot of Two Up riding with no problem. The 400 is a very capable bike, capable of going coast to coast, anywhere you want to go.
I recently bought an 06 Burgman 650 Standard with 10,000 miles on it, and have been riding it for 3 months. The 650 is real nice, but I still have the 400. I took the 400 for a ride across town yesterday, and it still amazes me how good it runs. As soon as I slide onto the seat I say how easy that is (lower seat). then when I take off I feel the lighter weight when I'm stopped at a light or parking lot. It's such a sweet ride, makes me wonder why I really need the 650. The only thing the 650's got going for it is that it is a little faster. The most noticeable part is that the 650 takes off much faster off the line. But the 400 is no slouch once it moves out past 50 feet!
Cheers!
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #5 of 14 (permalink) Old 04-07-2017, 10:04 PM
Insane Poster
Liamjs's Avatar
The 400 will have a little problem with that amount of weight, but will handle it fine. You will notice it's not so quick 2-up, especially coming off a GW. If you do a lot of riding with your wife, consider the 650. But for the occasional pillion ride, the 400 will be fine.
"What is your measure of success? Warren Buffett has always said the measure is whether the people close to you are happy and love you." Bill Gates
Liamjs
Ingrid - '07 Blue Burgman 400 (56k mi) - original owner
Jesse - '05 Silver Burgman 650 (27k mi) - 3rd owner
Liamjs is online now
post #6 of 14 (permalink) Old 04-09-2017, 02:32 AM
Insane Poster
E.D.'s Avatar
Oh I forgot to mention that I put the 16 gram sliders in my variator (very important), which helps a whole lot with the take off when riding 2 Up. For me the 16 grams sliders are perfect for me and my aggressive style of riding, IMHO.
Cheers!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #7 of 14 (permalink) Old 04-09-2017, 06:15 AM
Super Poster
SgtRV's Avatar
Don't understand the concern for load capacity. My '86 Goldwing Aspencade had a rather lower load capacity. But then it had a lot more power.
SgtRV is offline
post #8 of 14 (permalink) Old 04-09-2017, 11:36 AM
Insane Poster
Quote:
The OEM clutch is not quite for aggressive riding style.
Last true 400.
Bolzen is offline
post #9 of 14 (permalink) Old 04-09-2017, 02:31 PM
Insane Poster
E.D.'s Avatar
Quote:
The OEM Clutch worked good enough for me. I know the Dr Pulley HIT Clutch is better, but I just could not spend that much money on the Clutch. I never had any problem with the OEM Clutch, other than mine burned up at 25,000 miles (probably due to the poor thing trying to get my very heavy weight moving uphill). There were a lot of times that I had to START off from a light going UPHILL, and that would really stress and over heat the clutch. When I replaced the clutch, I went with the OEM Clutch because the cost was much less (still not cheap). and the EOM Clutch performed fine, and still is 12,000 miles later. I had to replace the OEM Clutch $145 + Clutch Bell $178 * shipping $20 = about $343. The Bell would have had to be replaced no matter which clutch I put in, as the Bell was completely burned blue and deeply scored to Dickens on the inside.
StgRV - The concern about LOAD CAPACITY is important because a vehicle can only carry a certain amount of weight safely, and can cause the suspension to bottom out. You cant ride the bike with your suspension bottomed out. On my 400, I set my rear suspension as tight as I can get it ()setting #7) and inflate the tires to the max, to support the heavy load that I mentioned above in my previous post. With that much weight, the suspension is near bottomed out, but not bottomed out. On the 400, the engine pivots and tilts down and the muffler rises in the rear as more weight is put on the bike. So when I am riding the 400 2 Up and fully loaded the Muffler is quite high in the back, but suspension is not bottomed out and does not bottom out in normal riding, but it would if I hit a big pothole. So I would say that the 570 pounds of load on the 400 would be the VERY MAXIMUM that that bike can carry, which is way over the recommended limit (which is why I bought a 650).
The 400 is am amazing bike with amazing capabilities.
Cheers!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #10 of 14 (permalink) Old 04-10-2017, 08:35 AM
Jim
Jim's Avatar
These older posts my help
#1
2009 Suzuki Specs.
400 GVWR 910
Curb weight 474 (standard) = 436 payload
Curb weight 489 (ABS) = 421 Payload
650 GVWR 999
Curb Weight (standard) 593 = 403 Payload
Curb Weight (ABS) 611 = 388 Payload
#2
Find the GVWR plate, minus the dry weight (405) minus about 45 lbs. for liquids should give you the payload. 2005 400 Specs.
Specs from an '04 (same model)
GVWR Front 280
GVWR Rear 580
GVWR 860
So, assuming the '04 specs are correct, 860 - 450 ish = 410 payload.
'07 and later
400 GVWR 910
Don't forget to adjust, for any other stuff you might be carrying aboard with you. That could add another 10-20 lbs., reducing the payload for people by that amount.
#3 A link to different bike Payloads
Would like suggestion for another bike
E.D. likes this.
Pictures of Modifications and Accessories
Jim is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Burgman 200 GVWR? largemanlittlebike Burgman 399cc and below 6 05-23-2015 06:14 PM
Burgman 400 GVWR -=GI=-KuriosYesous Burgman 400 (pre-2007) 4 05-25-2006 11:45 PM
Please comments on Burgman 400 vs. Yamaha Majesty 400 rvacs Newbie Questions! 26 04-16-2006 02:31 PM
GVWR of Burgman 650 gcheeseman Who are you? Where are you from? 5 12-24-2005 06:59 PM
Burgman 400 vs. Majesty 400 weight capacities Nake Burgman 400 (pre-2007) 8 08-08-2005 04:31 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
