Ignition problems? - Suzuki Burgman Forum
post #1 of 7 (permalink) Old 12-11-2016, 11:45 PM Thread Starter
New Member
Ignition problems?
Will a faulty ignition switch cause the bike not to fire? Also, the plug is completely dry. When I turn the kill switch to the on position with the ignition switch on, I can hear the fuel pump pressurize. But I am still not getting any fire. The starter turns the engine over fine. Today I installed a new battery, stator, crank positioning sensor, ecu and a new rectifier. I do not know what is wrong. I have checked the fuses and all of the connectors I have seen. Thanks
IsettaMike is offline
Sponsored Links
post #2 of 7 (permalink) Old 12-11-2016, 11:46 PM Thread Starter
New Member
I have also checked the codes and it has come back repeatedly c00
post #3 of 7 (permalink) Old 12-13-2016, 07:39 PM
NormanB's Avatar
Hi Mike
Thank you for your PM but question and answers should be placed in open forum - otherwise the real purpose of the forum (open forum information sharing), would be defeated. Thank you for your kind words though but you should read my signature - in addition I have not had a 400 for over 10 years so I can no longer profess to be at all familiar with them.
I take it your question concerns the 400 unit you are incorporating into the 1957 BMW Isetta?
Where are you located by the way, your profile is not complete? We encourage new members to do this and introduce themselves in the 'who are you, where are you from?' section.
I have read all of your posts on your project and you are clearly very technically competent and I hesitate to offer my meagre advice.
But first a couple of scene setting questions:
1. Have you ever witnessed this specific engine, that you are now fault finding, running?
2. Have you cranked the engine with the spark plug removed from the cylinder but connected by its HT lead and with the plug grounded to observe if it indeed producing a spark?
3. Have you ever done a compression test?
4. Have you read this thread and the successful conclusion of it?LINKY.
I am clutching at straws but aware you have done exhaustive (and no doubt frustrating) work already.
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
Last edited by NormanB; 12-13-2016 at 07:58 PM. Reason: Inserting a relevant LINKY.
NormanB is offline
post #4 of 7 (permalink) Old 12-13-2016, 08:31 PM Thread Starter
New Member
Thanks. Yes I have checked all of these that you have mentioned and it is the engine put into the Isetta. I don't know what else to do with it. I have also checked the F1 codes and it comes back c00.
post #5 of 7 (permalink) Old 12-13-2016, 08:32 PM Thread Starter
New Member
Also the engine was running great before the swap.
post #6 of 7 (permalink) Old 12-14-2016, 10:52 AM
Super Poster
Garage
New battery, ecu, crank position sensor, stator, rectifier means that there's only one thing left- the coil. Or possibly the wire to the coil. Or the wire from the coil. Or the grounding of the coil. If you've essentially changed the frame by sticking the engine in an Isetta, then there may be grounding problems.
Anyway, you need to do some basic troubleshooting- check that there's actually voltage from the crank position sensor while cranking- just use an AC voltmeter and make sure the needle blips each time around is enough. Then check that there's varying voltage going to the coil- same thing but the voltmeter on the coil's connections. If you get the needle blipping with the coil wire, then it has to be something with the coil or the way it's hooked up.
Good luck and please keep us informed of your progress!
Squeazel is offline
post #7 of 7 (permalink) Old 12-14-2016, 12:18 PM
Turbo Poster
Hussein Adil's Avatar
Garage
You may need to measure the resistance of the CKP sensor and then measure it again from the ECM side by unplugging the ECM and test the resistance from the ECM wiring harness (Refer to the manual to identify the pins of the CKP), if the resistance wasn't identical then you have a shorted circuit.
Also, check the fuel pressure from the injector side, if you have enough pressure then take the injector out and plug it back to the hose and hold it tight while putting the spray side in a jar then ask for someone to crank the engine for you and see if the injector is working or not, you don't have a working engine condition so the spray quality is not what we seek here, we just want to see if it inject fuel or not. But if you have no preassure then you have to take the pump assembly out to inspect it.
By the way, is your bike equipped with Suzuki Advanced immobilizer system (S.A.I.S)?
Learning patience.
Hussein Adil is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
No ignition peelbrow Burgman 650 4 09-12-2016 12:35 AM
Problems with the ignition switch johnd Burgman 400 (pre-2007) 4 07-21-2015 01:12 PM
Ignition Fuse trips when I turn on ignition. Please Help Sooners97 Burgman 400 (2007+ model) 5 11-12-2014 01:28 PM
Ignition Godzilla Bobber Burgman 400 (pre-2007) 3 08-06-2012 03:37 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
