Crank Position Sensor - Suzuki Burgman Forum
post #1 of 6 (permalink) Old 11-30-2016, 12:14 AM Thread Starter
New Member
I have narrowed my problem down to the crank position switch or the ecm. My fuel pump is working but not spraying any fuel and there is no spark. So I am going to try and replace both. Any ideas where to locate the sensor and ecm and the side cover gasket?
IsettaMike is offline
Sponsored Links
post #2 of 6 (permalink) Old 11-30-2016, 01:01 AM
Insane Poster
E.D.'s Avatar
Look first on ebay. good used parts for a lot less money
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #3 of 6 (permalink) Old 11-30-2016, 01:55 AM Thread Starter
New Member
Do the two parts I mentioned seem to possibly be my problem?
post #4 of 6 (permalink) Old 11-30-2016, 08:43 AM
Insane Poster
IF the CKP is the issue, I would crank the engine until I got an FI indication and see what the code is. You may have to crank for 5-10 seconds. I would expect a CKP diagnostic code (on the Boulevard series of bikes this is a C21 I think). Cranking for a while is the only way to get the code to show up in a no start situation.
When the engine is running, even a bad CKP may not show up as it is only degraded. TO get a CKP fault indication you pretty much have to have no output.
The sensor is only available as part of the stator assembly. When I replaced mine, I got it off ebay for about $70. New they're around $350-$400.
Ridin' the IceBurg - 10% transportation, 90% fun!
94K and counting.
Chatman128 is offline
post #5 of 6 (permalink) Old 11-30-2016, 03:04 PM
Insane Poster
E.D.'s Avatar
Test the peak output of the crank position sensor. When you pull the generator cover off, be sure to check the CKP sensor for any contamination or metal particles on it. Clean the sensor well, blow it off with compressed air and test it again before replacing. Any metal contamination on the CKP sensor may cause it to not work. Cleaning it may restore it's proper operation, if you are lucky. Note: The cover may have difficulty coming off. The shaft goes into a bearing in the cover, and sometimes it is stuck on there, so some careful prying may be required. Use some rags under the cover lip and some wood tools to pry the cover off, so as not to scar or damage the cover gasket sealing surface. Work slowly and carefully, pulling it straight off.
CKP sensor resistance 190 – 290 Ω
CKP sensor peak voltage 4.5 V and more (When cranking) (+) probe: G/W, (–) probe: Bl
DTC “C12” (P0335): CKP Sensor Circuit Malfunction
B705H11104016
Detected Condition and Possible Cause
Detected Condition Possible Cause
Although the intake pressure is fluctuated, the signal
does not reach for 3 sec. or more.
NOTE
If SDS is used, P0355 is indicated.
• Metal particles or foreign material being attached on the
CKP sensor and rotor tip.
• CKP sensor circuit open or short.
• CKP sensor malfunction.
• ECM malfunction.
Wiring Diagram components:
Generator-To regulator/rectifier
ECM
CKP sensor
CKP
On ECM: (3) CKP, (9)
Wires from Sensor to ECM: G/W, Bl
Sensor Wires: BI, G
Drawing #I705H1110012-02
Good Luck with it.
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #6 of 6 (permalink) Old 11-30-2016, 09:09 PM Thread Starter
New Member
Hey, thanks a lot!! I am working on it tomorrow and am checking everything you have mentioned. I noticed the outside of the three yellow wires coming out of the generator cover were very dirty. I will test clean and inspect everything. Thanks again
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Tps sensor position Johnvrt2001y General Discussion 0 08-26-2015 07:29 AM
Throttle Position Sensor. Buffalo Burgman 650 25 08-25-2013 05:36 PM
Primary Pulley Position Sensor (PPS) failure max_payne Burgman 650 7 09-04-2011 07:15 AM
cvt pulley position sensor seized up 3x's now bjyoung Burgman 650 16 02-22-2010 01:29 AM
Thermal sensor position in K5 or K6 b650 Marzio Burgman 650 4 12-03-2006 06:05 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
