Hard starting.. poor mileage.. stumbling - Page 2 - Suzuki Burgman Forum
 4Likes
Reply
post #11 of 15 (permalink) Old 02-14-2017, 06:35 PM
Insane Poster
E.D.'s Avatar
All the stuff that is posted above in good info. I would add to check your battery voltage, you should have at least 12.5 volts while idling and 14 volts or more when you rev up the engine to 5,000 rpm. That way you know that it is charging properly. Verify that the compression is good and then check valve clearances. Put in new correct spark plug and new air filter. Keep engine oil up to the full mark, but do not overfill.
Replacing a headlight bulb made it run better? That's a new one on me!
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
Sponsored Links
post #12 of 15 (permalink) Old 02-15-2017, 12:27 PM
Turbo Poster
xringracing's Avatar
That button is aftermarket, installed by a previous owner for something. That's not factory.
I'd put in a new air filter, new plug, fluid changes and put some miles on it to see if it clears up.
2004 Burgman 400
xringracing is offline
post #13 of 15 (permalink) Old 02-15-2017, 07:30 PM
Insane Poster
Replacing a headlight bulb made it run better? That's a new one on me![/QUOTE]
never seen it but I believe it, saw a fuse that wouldn't work upside down once, used a multimeter and tested it ! course I've seen a rhode Island red rooster do something to a honda motorcycle normally reserved for a hen , soooo.
close look at thumbnail doesn't look like aftermarket to me but still , would really like to know history on it .
never swim nekkid, they'll know who farted
mikeyMarine is offline
post #14 of 15 (permalink) Old 02-22-2017, 11:02 PM Thread Starter
New Member
Thanks for the input.
The odometer says 18,000 miles.
The battery passed all the multimeter tests. Tire pressure is good. No engine oil loss.
I'll check the spark plug number this weekend. The valve check may need to wait until Spring.
As far as the red button, the square molding around it sure looks like it was made with the rest of the dashboard. I checked the wires inside and they're dangling, unconnected. Maybe i'll connect a ship's air horn for the freeways.
John Holbrook likes this.
MooseMax is offline
post #15 of 15 (permalink) Old 02-23-2017, 05:50 AM
Insane Poster
E.D.'s Avatar
Smile
Quote:
Yeah, I put the Stebel Air Horn on mine, and it's a BLAST!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
This Helps Explain The Poor Mileage (and maybe more) happytech Burgman 400 (2007+ model) 8 11-06-2011 05:13 PM
hard starting bigbro_27 Burgman 400 (pre-2007) 4 05-19-2011 06:23 AM
2007 650 Exec with Poor Mileage - Help! DKD Burgman 650 13 09-16-2008 11:32 AM
Poor starting - battery or starter? poldark Burgman 400 (pre-2007) 10 02-23-2008 04:58 AM
windy trip - poor mileage and oil loss adentre Burgman 400 (pre-2007) 7 05-21-2007 05:58 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
