SAVED - by my ABS!!! - Suzuki Burgman Forum
Reply
post #1 of 38 (permalink) Old 03-02-2012, 04:34 PM Thread Starter
Turbo Poster
Steve D UK's Avatar
Garage
Yep, it's true, but I'm sure that some will disagree anyway.
On my way to work this morning. It was misty and the road was damp and greasy. I was filtering (lane splitting?) at about 15-20 mph between two lanes of stationary traffic when some bloody idiot in the passenger seat of a van in the right hand lane suddenly opens his door to lean out and empty an ashtray full of dog ends (cigarette butts) underneath his van! I was practically on top of him when he did this and just grabbed a big handfull of brake. The ABS worked perfectly. I came that close to the inside of the open door I had to back up to let him shut it - after I'd given him a mouthfull of abuse of course! Probably wouldn't have hurt myself but would have done sone damage to the front of my scoot if I didn't have good ol' ABS.
2011 AN650AL0 Exec - now gone
2010 Yamaha FJR1300
2009 Honda SH300i
1983 Puch Maxi 'pedal and pop'.
Steve D UK is offline
Sponsored Links
post #2 of 38 (permalink) Old 03-02-2012, 05:08 PM
Insane Poster
Bluebottle's Avatar
Re: SAVED - by my ABS!!!
Glad you are in one piece
Bluebottle is offline
post #3 of 38 (permalink) Old 03-02-2012, 05:19 PM
Active Member
MLavore's Avatar
It's good to know that you are alright and didn't sustain any damage to the bike, but it has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay, although it wouldn't have been as smooth
Knowledge is knowing that a tomato is a fruit, but wisdom is knowing not to put it in a fruit salad.
MLavore is offline
post #4 of 38 (permalink) Old 03-02-2012, 06:42 PM
Insane Poster
Quote:
If you're very trained.
ErikDK is offline
post #5 of 38 (permalink) Old 03-02-2012, 07:10 PM
Super Poster
EthanolBurgman's Avatar
It has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay . . .
What?
2005 AN650 Burgman ("chipped" ECM) running on E-85 ethanol.
Custom engine oil, transmission and final drive fluids.
BMC (FM388/19) Air Filter. Power Commander III.
Xenon Headlights
EBC HH Brake Pads and Rotors.
TCB on all Brakes.
Metzeler (Made in Germany) FeelFree Tires.
EthanolBurgman is offline
post #6 of 38 (permalink) Old 03-02-2012, 07:15 PM
Turbo Poster
Gbjbany's Avatar
Garage
must have been a day for it - Twice yesterday i had people change lanes in front of me ( one guy changed lanes 4 times - i guess he couldnt make his mind up) but whilst trying to avoid him i had taken my eye off the car in front of me and it had stopped - so i quickly grabbed a hand full, now i had plenty of distance but as it was wet and slippy the abs kicked in and made the stop less eventful than i think without. and as a new cyclist i dont have the extensive training others have so i probably overgrabbed !
Jeff
2015 Honda NC700XD
2008 Burgman 400
2011 Burgman 650 (sold)
Gbjbany is offline
post #7 of 38 (permalink) Old 03-02-2012, 07:17 PM
Active Member
MLavore's Avatar
Not necessarily, momentum on a motorcycle follows a linear path. It's a little bit different for a car that has two parallel points of contact that can be at different traction levels. (what tends to cause a spin).
By removing and reapplying brakes rapidly you aren't changing any factors then if you were applying brakes hard to begin with. The amount of force down on the brakepad and thus to the ground is the same, the rapid succession just keeps anything else effected by its momentum (rider) from being tossed forward as the transfer of momentum is the same but not constant like it is on non-ABS bikes.
When the brakepads on the ABS clamp down for those brief periods in rapid succession they are gripping full strength the same as you would do in a panic so that does not change, you just have more changes of momentum from front to brakes to front etc, this makes it so that the tires cannot slide any farther than the very brief point in which they are gripped each time. So basically if you were on a road slicker than snot and slammed the ABS brakes, the tires would still slide, but briefly and then return to having adequate grip to allow control. Rinse and Repeat.
Also, human reaction time going into the braking is what would have mattered the most, the 1.5 second average reaction time is what gets most people in trouble.
I supposed I could have explained that better. I am not against ABS by any means, they make panic stops a lot less intense/scary/coronary. Just saying that either way he should have been fine.
MLavore is offline
post #8 of 38 (permalink) Old 03-02-2012, 07:25 PM
Super Poster
. . . Also, human reaction time going into the braking is what would have mattered the most, the 1.5 second average reaction time is what gets most people in trouble. . . . Just saying that either way he should have been fine.
Let's see what that might look like . . . http://www.youtube.com/watch?v=ds4bRTZfS3g
Xenon Headlights
TCB on all Brakes.
post #9 of 38 (permalink) Old 03-02-2012, 07:43 PM
Active Member
MLavore's Avatar
This is why I like cars that have doors that are locked shut until the vehicle is taken out of drive... It doesn't completely remove the risk but i'd imagine it helps reduce the amount of people opening doors.
MLavore is offline
post #10 of 38 (permalink) Old 03-02-2012, 09:46 PM
Insane Poster
rustynail's Avatar
One more anecdote...
I'll not rehash any of the debunking here - as the OP was an active participant in my anti-ABS rant.
Steve D, I'm glad you're okay. Truly.
Motorcycle **** is riding a loud, heavy cruiser shoed with a car tire on the uninspiring interstate highway system. I chose something else.
rustynail is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Would ABS brakes have saved my crash? Allred General Discussion 50 08-28-2011 12:04 PM
A white helmet saved a life! Garnet Safety Tips and Ideas 17 11-23-2010 04:39 PM
How the CVT saved my love of 2 wheeled powersports! Scootereno General Discussion 2 09-25-2009 07:56 PM
Sidecar saved the Burg welnet General Discussion 3 10-01-2008 08:00 PM
Can my AN400 be saved? 37 eeyore Burgman 400 (pre-2007) 7 01-08-2006 11:19 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
