Changing your own tires - Suzuki Burgman Forum
Reply
post #1 of 14 (permalink) Old 04-06-2011, 11:08 PM Thread Starter
Active Member
How many have done this? Last summer I put new tires on my 2004 Burgman 650. With help from Ledude's how to videos I was able to swap out the front tires myself.
But the rear tire sideway was soooo stiff I was unable to make much headway after several minutes. So, I placed the tire/wheel in the back of my Dodge truck and went to my local Yamaha dealer. The nearest Suzuki dealer is about 25 miles.
The service guy at Yamaha placed the wheel on his tire changer and had it swapped in about 5 minutes or less. Charged $25.00. I put on new Diablo's.
Well here it is next spring and I need tires again. Less than 5,000 miles and both need replacing. The back tire has turned flat in the center and the front has worn to the treadwear indicators.
Sooo, I'm putting OEM Bridgestones back on.
clava is offline
Sponsored Links
post #2 of 14 (permalink) Old 04-06-2011, 11:35 PM
Super Poster
wa9w00d's Avatar
Re: Changing your own tires
Hi Clava, I know you've been here a while, but welcome anyway.
The secret to removing or installing a tire is to make sure the side opposite to the side you are trying to bring over the rim stays down in the smallest part of the wheel. I know this isn't the greatest description, but if you think about it a few minutes, it makes sense. there is always a recessed area in the middle of a wheel. That's there for one reason. To give the bead of a tire (which cannot be stretched), a place to occupy while being changed to an oblong shape whilst moving on or off the rim.
Wayne
The sooner I fall behind, the more time I have to catch up.
Givi screen, DPS 18gram, Yoshimura exhaust
Wayne
wa9w00d is offline
post #3 of 14 (permalink) Old 04-07-2011, 09:08 AM
Turbo Poster
Aladinbama's Avatar
I tried last summer and failed. Apparently (even to the guy who eventually put it on with a machine), the tire I chose to mount was pretty tight. After about a half a day of trying I gave up and found a tire shop nearby that will do it for $10.00. I figure for $10.00 what the heck - my time is worth more than that. He's changed three for me since last fall (two bikes).
Aladinbama is offline
post #4 of 14 (permalink) Old 04-07-2011, 02:38 PM
Insane Poster
paulcbrowne's Avatar
The front is much easier than the rear. The rear is very stiff. I've had motorcycle shops tell me that the only tires of equal difficulty to install are on a Gold Wing or BMW LT. That said, I have done mine, but it's just about not worth the hassle. I have all of the proper gear, but next time I'll let the dealer do it.
Shepherdstown, WV USA
paulcbrowne is offline
post #5 of 14 (permalink) Old 04-07-2011, 07:24 PM
Insane Poster
Scootereno's Avatar
Mounting tires is a dirty labor of love without a machine to mount and demount them. I still use the old tire irons I got back in nineteen hundred and seventy four and even with all the experience and tips I've learned along the way it can still be a pain depending on the tire. A second person helps when the tire is being stubborn.
ScooteReno aka Steve-a-Reno
Basically Stock
Sheepskin Pelt
2.1 MP3 Stereo
Averaging 70mpg
Scootereno is offline
post #6 of 14 (permalink) Old 04-07-2011, 07:50 PM
Insane Poster
LeDude's Avatar
the Burgman 650 and the Honda Goldwing have two of the hardest tires to change by hand...
I don't think the Goldwing tire can be mounted without the help of a tire mounting apparatus of some sort ...
the Burgman 650, even though extremely stiff, is doable with a bit of planning and preparation.
I was going to do a video on it but decided to hold off fearing that people may end up damaging their rims / tires.
that last 20 inches on the 2nd bead on the rear tire can be really hard to overcome.
spending $10-25 every 10-15k miles to have a new rear tire mounted/balanced is well worth the labor price and time saving and hassle.
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #7 of 14 (permalink) Old 04-08-2011, 05:15 PM
billmeek's Avatar
Check around at some of the local car tire shop and ask what they will charge to mount a motorcycle tire to a rim if you bring it to them off the bike. I found a small local shop that will mount the tire and spin balance it for under $10 per tire.
Bill
'03 Burgman 400 in blue
'03 Burgman 400 in silver (rebuilt)
'08 Burgman 400 in red - FOR SALE
'13 Honda PCX 150 in red
"Yes, I ride it all year round. No, I'm not insane. I'm poor. With insane, you get free room and board."
billmeek is offline
post #8 of 14 (permalink) Old 04-09-2011, 04:15 PM
Active Member
Had pretty much the same experience. Battled with the rear tire for about an hour, took to cycle shop, walked out 20 minutes later with mounted tire for 25 dollars. Haven't tried to change it myself since.
Seneker is offline
post #9 of 14 (permalink) Old 08-02-2011, 05:24 PM
Insane Poster
happytech's Avatar
Watched the video but I have a couple of quick questions.
1. Tire indicator (spot, etc.) - always lines up with the valve stem - correct?
2. What I'm wanting to do is simply switch out the stock valve stems with some low-profile valve stems. Is it possible (and simple) to simply deflate the tire (wheel removed), break the beed around that area, switch out the valve stems, reinflate and reinstall tire? Am I missing something here or do I have the basic idea?
3. I'm still a bit confused on the initial removal/bead break - do I apply silicone to the tire before I break the bead and then again before I reinflate?
Thanks,
Bruce
Iím not afraid to go fast Ė itís the crashing and burning that scares me.
Actually, I'm too cheap to go too fast. Have you seen the price of gas lately?
It's SO time for another long road trip!!! - like THAT'S ever going to happen now.
happytech is offline
post #10 of 14 (permalink) Old 08-03-2011, 09:48 AM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
Dirty jobs work oh-so-much better with the proper tools...
has anybody tried or bought this tool?
http://www.google.com/#q=motorcycle+tir ... 80&bih=864
For $100 or so, you can't go wrong. At $39 a pop for tires, it could pay for itself after the third tire.
Here's a review of one:
.."Although there were cheaper brands, I found only one motorcycle tire changer that mentioned that their clamping system and bead bar were designed specifically not to mar any wheel, and hence their name, No-Mar."
http://www.webbikeworld.com/Motorcycle- ... e-changer/
Of course, the No-Mar will set you back nearly a grand.
..."Cost - Savings Equation
The No-Mar "Ultimate Package II With Large Coneset and SpoonBars" motorcycle tire changer shown here costs $895.00 + $80.00 shipping. We exchanged the wheel balancer ($99.00 list), which we didn't need, for the hitch mount ($89.00 list) and saved $10.00. The shipping cost was $79.68 for a total of $964.68.
This means that the No-Mar motorcycle tire changer will pay for itself in 16 tire changes (front and rear). While that may seem like a lot, Chris has 135,000 miles on his BMW K1200LT. If the average set of tires last, say, 8,000 miles, that's 16 changes right there during the life of the bike.
And Chris has two other bikes, I have 3...so the savings adds up pretty quickly. Not to mention that the convenience factor -- we can change tires when we want to and when we need to with no waiting, and we know the job is done right. And since the nearest motorcycle shop is about 15 miles away, add some savings from driving back and forth; four trips, to go there, leave the tire and rim, then go back and pick it up in a couple of days.
No-Mar says that many groups, clubs or friends have split the cost of the changer, which can reduce the payback period dramatically. If the cost was split four ways, for example, each joint owner could theoretically pay back the investment after 4 front/rear changes..."
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Changing Your Tires Bakeisback General Discussion 16 11-15-2010 02:08 PM
Changing from a 650 to a 400? billbytheway General Discussion 17 01-16-2010 07:26 PM
Changing your own tires happytech General Discussion 11 07-15-2008 07:49 PM
Changing Tires Old Biker Burgman 650 5 08-12-2005 12:36 PM
Changing to Pirelli Tires lifegetter General Discussion 12 04-02-2005 01:20 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
